1Back to top Go down   air/fuel mixture Empty air/fuel mixture Thu Sep 05, 2013 12:48 pm
k-rider
k-rider
hi , does anyone no if there is a way of checking/adjusting the co-level without a co-gauge, i read somewhere ,cant seem to find it, that Theres a trick with depressing the starter button with the engine idling, anyone?Idea
2Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 1:01 pm
zonenfeile
zonenfeile
pls do not "adjust" anything before all points from the "Wrong Air" list have been checked and the valves have been adjusted
1st lesson:
download the manual
2nd step
- let the engine run (warm)
- brake cleaner spray directly to all parts of the throttle unit
if you have any changes in running you have it (the bug)
btw: sometimes K Wiki - 13 helps
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
3Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 2:01 pm
japuentes
japuentes
Hi there, this is the link
http://skylands.ibmwr.org/tom/tech/co-setting.html
Also a lot of useful data in that site.
Best regards
JAP
air/fuel mixture 2854237993 1988 K100RS SE/ABS
4Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 2:12 pm
k-rider
k-rider
zonenfeile wrote:pls do not "adjust" anything before all points from the "Wrong Air" list have been checked and the valves have been adjusted
1st lesson:
download the manual
2nd step
allready did the brake cleaner thing , no issues there, but i guess i will download the manual , is it availlible here on the site?
btw. the reason i am asking is that i get a decrease in rpm. when  pressing the starter button while the engine is idling.
5Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 2:14 pm
k-rider
k-rider
japuentes wrote:Hi there, this is the link
Best regards
JAP
thanks , thats the one i was looking for ,guess i will have too make some adjustment:)
6Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 10:55 pm
brickrider
brickrider
That instruction states the air bleed screws are typically best set 4-5 turns out.  Can that be correct?
I'm sure I've never had carburettors or FI bodies that were set in that range.  Having said that, my K100RS does seem to smell like the mixture is too rich at idle, but performance wise, it runs very well.
7Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 11:11 pm
they are talking about the air bleed screw in the afm brickie ....that lets air pass at idle ...before the afm opens up ....after throttles open .......some air has to be able to make it to the tbs at idle before opening the afm ?
8Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Thu Sep 05, 2013 11:36 pm
It also states that if you push the start button the idle will increase slightly.
I dont know where that came from but it cannot possibly happen because if the engine is running over 711rpm the start button is disabled and it can't possibly send a signal to anywhere.
9Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Fri Sep 06, 2013 5:35 am
RicK G wrote:It also states that if you push the start button the idle will increase slightly.
When the engine is running above 711 rpm, the ground side of the starter relay
coil is disabled....to prevent the starter from turning.
The starter signal is still present, as long neutral is selected or clutch pulled.
10Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Fri Sep 06, 2013 7:37 am
Thanks Inge I stand corrected. I was thinking of the guys who have said that you push the starter button when overtaking and they get more power and took it from there that the starter was totaly without battery over 711 but that was because the clutch was not pulled in so it could not happen.
If it is sitting in neutral it works but not moving on the highway.
11Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Fri Sep 06, 2013 12:08 pm
k-rider
k-rider
Well now i have followed the instruction and it does seem to ryn better at idling speed.
I am going for a 150 km run tomorrow tjen i will see if theres any improvement.
Just for the record , how much , if any at all, does this adjustment of the co level at idle speed affect the mixturr ratio above idle speed?
12Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Fri Sep 06, 2013 1:05 pm
nearly nothing .......its just for compliance with emission standards ...as the maf mapping takes over just a few hundred revs more than idle
13Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Fri Sep 06, 2013 9:59 pm
japuentes
japuentes
Hi there, I've noticed that this regulation is important, if is not correct the bike will jerk while passing from idle to open throttle or the engine will stall if you suddenly cut the gas and engage the clutch.
Best regards
JAP
14Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Mon Sep 09, 2013 2:52 pm
k-rider
k-rider
well, thought i would give you an update.
after following the instructions above  it really runs smoother at idle than ever before, also the overall rev range is smoother with far less vibration than before, funny, i thought that syncronising the tb¨s an adjusting of the co-level , would only have effect at idle speed, but no:D
its nic to be a brickowner:twisted:
15Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Mon Sep 09, 2013 9:10 pm
brickrider
brickrider
K-Rider, now that you've tuned it to your satisfaction, approximately how many turns from full in and seated are the throttle bodies' air bleed screws?
16Back to top Go down   air/fuel mixture Empty Re: air/fuel mixture Tue Sep 10, 2013 12:32 pm
k-rider
k-rider
brickrider wrote:K-Rider, now that you've tuned it to your satisfaction, approximately how many turns from full in and seated are the throttle bodies' air bleed screws?
just about 5/4 turns
and it idles at approximatly 900
