1Back to top Go down   Fork Sliders  Empty Fork Sliders Thu Aug 29, 2013 1:21 am
jjefferies
jjefferies
Probably appropriate for either 75 or 100 but specifically I'm dealing with a K75. I've got a little click (felt rather than heard) sometimes when I hit the front brakes. I first thought it was the head needing to be tightened. But I've tightened it down enough that I'm worried that I'll brinnel the head bearings which have less than 5K miles on them. I've checked the other bolts on the front end and everything "seems" to be done up properly. So now I'm thinking fork tube sliders? (inner tube, part 3 in this diagram)
Fork Sliders  B0000609
Now the bike and the part have 147,000 miles so wear is not unexpected. But is replacement the only option? Are there renewable parts for such an affliction? The fork seals are holding and I can probably live with the click for the moment any way. No way I'm messing with them before finishing the Range of Light Gypsy tour this weekend.
But any suggestions of what to look for or other options to look at?
thanks
J.
2Back to top Go down   Fork Sliders  Empty Re: Fork Sliders Thu Aug 29, 2013 1:25 am
Check out the pads and calipers I have seen them making noises like that.
3Back to top Go down   Fork Sliders  Empty Re: Fork Sliders Thu Aug 29, 2013 1:29 am
MikeP
MikeP
I'd look at the brakes first. The locating pins and the corresponding holes in the pads can wear and become oval which allows the pad to move when the brakes are applied.
Edit: Not quick enough!
4Back to top Go down   Fork Sliders  Empty Re: Fork Sliders Thu Aug 29, 2013 5:21 am
jjefferies
jjefferies
Thanks guys, will check the brakes before I do anything drastic. Still did feel like the headstock. But brakes are so much more readily fixable.
