1 92 k75 needs some expertise on an issue Mon Aug 19, 2013 9:43 pm
MikeisonTV
So my 92 K75 is doing some strangeness!!! Sometimes in 1st gear/ neutral, the RPMs will fly way up like the throttle is wide open even in the "down" position. I look at the fine tuning adjustment screw where the throttle cable meets the engine and its down....if I push down on it during the peak of the throttle gain, it seems to move down just a few mm and in 5 sec or so usual to a normal Idle.
It also will choke out when downshifting with no throttle as I'm slowing to stop every now and then. If I hold the throttle open with the clutch in....I can cheat it from choking out. But, obviously not ideal for long term....thoughts?
I have changed the throttle cable out and it could be the original. Doesn't seem to be sticking and returns to the bottom pretty easily.
