1 1985 Bmw K100FF Sat Aug 10, 2013 1:07 am
FFC
What's up everybody. My name's Drew and I'm in the process of building a custom kbike. The upgrades I've done so far include new cold air intake, new exhaust (Remus), larger injectors. I've bobbed the tail and powdercoated most of the bike. I tore the bike down to make sure everything was still in spec. MaxBmw is in my hometown so luckily it's a short trip and I have become a regular there.. I've spent an arm and a leg on oem parts for this bike from rebuilding the water pump to rebuilding the fuel pump and all associated gaskets to wheel bearings. I've updated the clutch push rod and alternator, and the list goes on. I fitted an Ohlins rear shock to the rear and have mounted 2008 gsxr 1000 front forks, fitting the gsxr forks and brakes to the bmw wheel took a ton of work.
Ill keep you guys updated with pics when I can.. I need to wire the bike, make rearsets and a tail section and it should be ready to rip.
