1 TPS switch. The next step? Sun Aug 04, 2013 8:52 pm
Comberjohn
After much thought I recently cut the black/white wire going to the TPS or butterfly switch as its also known as.
The bike is now much smoother when slowing down and I really prefer it this way.
BUT. Because the engine doesn't have the same engine braking the brakes need to be used a bit firmer and this is where my problem comes in. Have a touch of arthritis in my thumbs and after a hundred or so miles, my hands are getting a bit sore.
The intention was to install a switch to give me the choice of having it or not and was thinking about where to put the switch.
That's when I came up with the idea.
What if the black/white wire that was connected to the TPS was connected to the brake light?
If you were sitting at, say, 60mph and backed off the throttle but wanted a bit more engine braking. A light touch on either brake and the fuel shuts off and slows the bike down more. Below 2000rpm, no difference anyway.
Release the brake and back to normal.
I was thinking of running a temporary wire to try out the theory.
Unless I've sat up too late and someone can point out the bleeding obvious to me!
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
