1Back to top Go down   starter motor brushes Empty starter motor brushes Tue Aug 20, 2013 7:20 pm
michaellaw
michaellaw
Hi everyone can anyone tell me weather the length of the starter motor brushes are 12mm all up or 12mm from the end of the housing they are cased in looks like im making my own
2Back to top Go down   starter motor brushes Empty Re: starter motor brushes Tue Aug 20, 2013 7:42 pm
I cant tell you the exact length but when new the top of the brush sits about 1mm maybe 2mm below the top of the little rectangular holder, I presume that is to prevent the spring slipping of the top and losing tension.
I looked into a source of these and came up with zip but in my investigation worked out that they need to have 5mm of brush to wear away.
3Back to top Go down   starter motor brushes Empty Re: starter motor brushes Wed Aug 21, 2013 2:10 am
the kit from the 'bins is not expensive
includes the backing plate and both brushes ....this way you get new springs and properly welded up and new cable between the brush and the contact points
have done a fair bit of brush shaping ...from the wrong size to the correct one ...with a file ...(it isn't hard ) but connecting the flexible cable from the brush can be a  bit hard,,, the soldering process works but it weakens the first few millimeters near the joint  with the solder , creating a good fracture point .
good luck !
4Back to top Go down   starter motor brushes Empty Re: starter motor brushes Wed Aug 21, 2013 1:45 pm
Hi Michael, I've just measured a new brush.
It is 12mm x 5.91mm x 8.87mm
 starter motor brushes Sam_0712
