1Back to top Go down   Don't Call it a Cafe Racer! Empty Don't Call it a Cafe Racer! Sat Aug 03, 2013 10:51 am
papajhotel
papajhotel
http://papajhotel.wordpress.com/2013/07/01/the-k100-project/
Above is the link to the blog I'm running on my K100 conversion. If successful, I think it will end up sort of half way between a street fighter and café racer. I'm about to fit the Dakota Digital speedo, so any advice is welcome! I emailed Dakota Digital before purchase, and they advised I could use the BMW rear wheel speed sensor. After browsing the forum, I'm not so sure!
1984 K100RS
2005 K1200R
2Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Aug 03, 2013 4:45 pm
Erman
Erman
I like it! Where did you get the exhaust collector?
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
3Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Aug 03, 2013 5:00 pm
papajhotel
papajhotel
Erman wrote:I like it! Where did you get the exhaust collector?
 Found it on eBay. A guy was selling an after market can off a K100LT. I bought it for the collector, told him to bin the can and just post the collector!
1984 K100RS
2005 K1200R
4Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Aug 03, 2013 11:20 pm
I see so many K Bike café racer projects and can only guess that its a cheap entry level project for the younger blokes. Don't get me wrong I like a good café bike, and I like the look of some of the café K's. But will your sweet sounding fuel injected flat four with self cancelling indicators really shake the windows of the pub when you arrive. I guess you'll have to leave that part to the fast back Nortons . Beauty really is in the eye of the beer holder. Good luck with the project.
      Smithy
5Back to top Go down   Don't Call it a Cafe Racer! Empty Pretty much done! Fri Oct 11, 2013 9:53 am
papajhotel
papajhotel
From this
Don't Call it a Cafe Racer! PjB_abEzMsKzF0rskwgz1wqic6pCFed_0j1Epqq8v6g=w388-h218-p-no
To this in 4 months. I'm pretty happy for my 1st build.
Don't Call it a Cafe Racer! K100+Project+%252898%2529
Don't Call it a Cafe Racer! K100+Project+%252897%2529
1984 K100RS
2005 K1200R
6Back to top Go down   Don't Call it a Cafe Racer! Empty Now to get it running right! Fri Oct 11, 2013 9:56 am
papajhotel
papajhotel
After putting it back together it starts, sometimes idles, but dies with throttle. I replaced the fuel filter when I had the tank off. I'm thinking air in the lines. Any advice appreciated!
1984 K100RS
2005 K1200R
7Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Oct 11, 2013 10:06 am
Check that the throttle position sensor is plugged in properly and also the Mass air flow sensor or air flow meter and some call it is plugged in and the temp sensor on the side of the air box
8Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Oct 11, 2013 10:12 am
I like how you have removed that superfluous piece of fuel tank....very tidy " non Cafe racer"
By the way Hutch I used to work on A21-22 prior to working at ARDU in the late 80's small world hey.
Last edited by Klompy the grey brick on Fri Oct 11, 2013 10:22 am; edited 1 time in total
KKlompy Don't Call it a Cafe Racer! 2854237993
Don't Call it a Cafe Racer! Au-log10
9Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Oct 11, 2013 10:16 am
looks sweet
should howl a little
good job !
10Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Oct 11, 2013 10:48 pm
papajhotel wrote: I emailed Dakota Digital before purchase, and they advised I could use the BMW rear wheel speed sensor. After browsing the forum, I'm not so sure!
Not without a conditioning circuit.  I built one based on a schematic published on Motobrick.  Video below shows my bench test of the circuit:
https://youtu.be/lgKV51duIjk
The LED blinks for each time the final drive sender passes by the speed sensor.  The blinking is hard to see because it is short in duration.  The output is normally high (+5V) and goes low for each transition.
Don't Call it a Cafe Racer! DSC_0034
11Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Oct 12, 2013 9:31 am
papajhotel
papajhotel
Thanks Rob,
I ended up running a sensor to the front wheel. I calibrated it today, works fine.
1984 K100RS
2005 K1200R
12Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Oct 12, 2013 9:34 am
papajhotel
papajhotel
RicK G wrote:Check that the throttle position sensor is plugged in properly and also the Mass air flow sensor or air flow meter and some call it is plugged in and the temp sensor on the side of the air box
Thanks Rick,
Kicked it over today and it ran fine! Been on a maiden voyage!
1984 K100RS
2005 K1200R
13Back to top Go down   Don't Call it a Cafe Racer! Empty Thumbs up! Sat Oct 12, 2013 10:39 am
xpc316e
xpc316e
I have just checked out the blog of your build, and found your project really interesting.  I must first admit that I am not the world's biggest fan of the café racer style, but when a job has been done properly I can appreciate it.  I shall not be ripping off fairings etc. to follow your lead, but it must be said that you have created a gorgeous machine.  Some of your solutions to problems are really innovative and elegant.
14Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Oct 12, 2013 11:09 am
xpc316e wrote:I have just checked out the blog of your build, and found your project really interesting.  I must first admit that I am not the world's biggest fan of the café racer style, but when a job has been done properly I can appreciate it.  I shall not be ripping off fairings etc. to follow your lead, but it must be said that you have created a gorgeous machine.  Some of your solutions to problems are really innovative and elegant.
Exactly.
We can't all agree on what is nice and what is not, but we can all agree on a job well done.
Very nice work.
Oh, I do like it.
15Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Oct 12, 2013 6:23 pm
AJ.Valente
AJ.Valente
Good job.
I really like that "hornet orange."
I'm planning a re-spray of my bike next year (as soon as I finish paying it off) and am going away from the traditional red brown to something more like an orange brown.
Hard to tell from photos alone, does hornet orange have any metal flake in it?
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
16Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sun Oct 13, 2013 12:38 am
papajhotel
papajhotel
AJ.Valente wrote:Good job.
Just a little! More flake than I expected. It is apparently a fairly new product line called 'vibrance'.
Don't Call it a Cafe Racer! K100+Project+%2528100%2529
1984 K100RS
2005 K1200R
17Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Thu Nov 14, 2013 12:33 pm
Moomin_Man
Moomin_Man
Scrolled through your blog in a state of awe! Simply stunning!
18Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Thu Nov 14, 2013 1:10 pm
papajhotel
papajhotel
Moomin_Man wrote:Scrolled through your blog in a state of awe! Simply stunning!
Thanks for the compliment! I'm planning to take it to Tasmania in Feb 2014 for some more sport touring duties.
1984 K100RS
2005 K1200R
19Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Thu Nov 14, 2013 9:25 pm
MT350Explorer
MT350Explorer
Exactly.
Very nice work.
Oh, I do like it.
+1. Great work. Very Happy
1991 K100 RS 16 valve
20Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Nov 15, 2013 6:39 am
TöbendenStièr
TöbendenStièr
big fan of the look you have created
in terms of the instrument cluster what have you done there?  Picture???
21Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Nov 15, 2013 6:51 am
papajhotel
papajhotel
TöbendenStièr wrote:big fan of the look you have created
The unit is from Dakota Digital. There is a hyperlink on the blog to their site. Very smick. It gives 0-100km/h times, 1/4 mile times. Peak speed and rpm. Gear postion indicator via matching speed to rpm. Will update photos and setup when I get home on Sunday.
1984 K100RS
2005 K1200R
22Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Nov 15, 2013 6:56 am
TöbendenStièr
TöbendenStièr
no need for posting pics
just took a look at the blog-it's all there
awesome work
23Back to top Go down   Don't Call it a Cafe Racer! Empty NICE! Fri Nov 15, 2013 4:33 pm
ssj_Gill
ssj_Gill
i like what you have done, very similar to what i'm trying to achieve. what have you done with the two computer boxes though? i dont have space under my tank for them
24Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Fri Nov 15, 2013 11:44 pm
papajhotel
papajhotel
ssj_Gill wrote:i like what you have done, very similar to what i'm trying to achieve. what have you done with the two computer boxes though? i dont have space under my tank for them
I only had the Bosch ecu box to relocate. I have it bolted to the underside of the seat pan, between the frame rails.
1984 K100RS
2005 K1200R
25Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sat Nov 16, 2013 8:28 am
MikeisonTV
MikeisonTV
Awesome K conversion! I'm trying to use a Dakota Digital speedo myself….having trouble with the Pulse. Did u add a Dakota Digital brand speed sensor to the front wheel or?
26Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Sun Nov 17, 2013 1:05 am
papajhotel
papajhotel
MikeisonTV wrote:Awesome K conversion! I'm trying to use a Dakota Digital speedo myself….having trouble with the Pulse. Did u add a Dakota Digital brand speed sensor to the front wheel or?
I did use a Dakota Digital sensor, it counts the wheel studs
Don't Call it a Cafe Racer! K100-project-78a
1984 K100RS
2005 K1200R
27Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Thu Dec 12, 2013 9:13 am
MikeisonTV
MikeisonTV
Robmack, do you have any pics of the underside of your circuit?
I'm going to attempt this in a week or so. I have the parts list you sent me but don't know in what order to solder the pieces. I'm more of the mechanical mind than the electrician.
28Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Tue May 05, 2015 3:37 am
JR_K100RS
JR_K100RS
G'day PJH ,
                 spotted the bike heading outbound on the Eastern freeway yesterday morning at 11.30am ( I was driving inbound ) jeez it doesn't half stand out , the orange caught my eye 1st then that crazy ducktail ! , hope it's still going well
John R
29Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Tue May 05, 2015 3:45 am
papajhotel
papajhotel
JR_K100RS wrote:G'day PJH ,
John R
Hi John,
It's going great! I'm hardly riding my K1200R at the moment. Every time I go to ride somewhere I pick the K100!
1984 K100RS
2005 K1200R
30Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Tue May 05, 2015 3:52 am
JR_K100RS
JR_K100RS
Well done you !
Ciao
John R
31Back to top Go down   Don't Call it a Cafe Racer! Empty Re: Don't Call it a Cafe Racer! Tue May 05, 2015 8:39 am
Busas
Busas
Hi,
Nice Job and Amazing atitude.
Congrats
