mud1
mud1
Hi all, it's very early days for my K100 resto but I was wondering if it was possible to put a radio on my RS? I have searched, but not found the answer. I realise it's a bit old hat, but I kinda like the idea and if wasn't too much trouble I was going to look for the bits on Ebay. Any help would be great.
Cheers Mud1
I would have thought that these days a bluetooth headset and a Mp3/radio (mobile phone?) would be much easier than finding the room for a radio in the RS fairing.
There is no OEM radio for an RS but where there is a will etc. The LT in the K100/75 and K1100 all had a radio as optional equipment and a place to put them in the left side pocket, unfortunately or as some would say fortunately the RS didn't have any provision for one. If its music you want then a small mp3 player with earphones in the helmet is a good way to go.
Check this link
Max output power: 2X 6W (good enough if you use earphones).
Can I fit a radio to my 1990 K100 RS 16V? 469705968_o
Can I fit a radio to my 1990 K100 RS 16V? Frog15Can I fit a radio to my 1990 K100 RS 16V? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Can I fit a radio to my 1990 K100 RS 16V? Empty Thanks Thu Apr 18, 2013 3:34 pm
mud1
mud1
Thanks very much for all the replies, the one pictured looks like a much better ideal with a lot less hastle!
Cheers Mud1
Stephen Hyndman
Stephen Hyndman
Hello. I mounted a 4 channel 100 watt am/fm with line in and USB. I installed it into the tail cowl. I ran a 6 foot line in cable out under brake lamp and under the seat tank. Mounting a clip on 2g iPod nano to the left side of the dash pad. You can control the volume and hit pause at lights. Charges my iphone in the tail cowl while driving. You just have to remember to take the iPod when you park. The speakers are 4inch square ones. I removed the black side covers and they fit perfect. The magnets hold them to the steel below the temp and fuel gauges. With the covers back on they seem well protected from rain. I got the unit on eBay from Hong Kong. The only part you see is the end of the cable by the dash pad when it's parked. Can take photos if you are interested.
Stephen 1989 K100RS SE - WB1050305k0147914
We're always interested in pictures, Stephen.
Even if we don't want to fit a sound system, we'd like to see what you've done.Can I fit a radio to my 1990 K100 RS 16V? 112350
Just for info (I know the thread is about RS and not RT)
I fitted my marine radio in the the left glove box of the RT.
Front channels are feeding the speakers in the fairing, and rear one are feeding the ones in the sidecar.
During the week I will put the rig apart in order to take it outside.
When people see it in the basement, the first reaction is WTF.... The door is only 29" wide, 3' under ground level with a sharp 90 degrees angle to access it Very Happy
Can I fit a radio to my 1990 K100 RS 16V? Dsc_2412
MT350Explorer
MT350Explorer
Stephen Hyndman wrote:Hello. I mounted a 4 channel 100 watt am/fm with line in and USB. I installed it into the tail cowl. I ran a 6 foot line in cable out under brake lamp and under the seat tank. Mounting a clip on 2g iPod nano to the left side of the dash pad. You can control the volume and hit pause at lights. Charges my iphone in the tail cowl while driving. You just have to remember to take the iPod when you park. The speakers are 4inch square ones. I removed the black side covers and they fit perfect. The magnets hold them to the steel below the temp and fuel gauges. With the covers back on they seem well protected from rain. I got the unit on eBay from Hong Kong. The only part you see is the end of the cable by the dash pad when it's parked. Can take photos if you are interested.
Yes please do mate, I am planning a similar mod and would be interested to see what you've done.
Dave
1991 K100 RS 16 valve
10Back to top Go down   Can I fit a radio to my 1990 K100 RS 16V? Empty ariel Sun Aug 04, 2013 10:20 am
badgerdid
badgerdid
Crazy Frog wrote:Check this link
I tried something similar, there great for mp3's but the radio Ariel uses a single wire and i found it wasn't much good at picking up radio channels, if it had a proper Ariel socket it would have been great.
