1Back to top Go down   Powder Coating Front of K engine Empty Powder Coating Front of K engine Wed Jul 31, 2013 4:07 pm
jjefferies
jjefferies
I'm in the middle of a project to restore a K75C and have pulled the engine and am considering powder coating the several engine covers. In the past I have powder coated the Valve and Crankcase covers and had reasonable results. But now I'm looking at the timing belt, Hall's effect and oil/water pump covers and wondering if it makes sense to do them. The considerations seem to be that these parts take the most beating in terms of sand, rock and road debris. Powder coating while enhancing protection still is subject to damage. Does it make more sense to leave these parts as painted and be able to simply hit them occasionally with spray paint? If they are powder coated and are damaged that might mean more difficulty in dealing with  cosmetics. Yeah, I suspect it's my feminine side.
thanks
J.
2Back to top Go down   Powder Coating Front of K engine Empty Powder Coating Front of K engine Wed Jul 31, 2013 8:08 pm
Hi mate
my tuppence worth is just paint it with heat resistant paint every now and again, wash it down every now and again and spare that expense. If your side covers look good anyway no body will notice a few chips on the front. I painted mine 2 years ago and is just now ready for another coat after about 25,000 Kilometers.
Good luck
3Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Wed Jul 31, 2013 8:19 pm
The thing about powdercoating is that it will work fine but when it gets damaged [as it will from chips etc] moisture and corrosive salts get through and get trapped underneath the coating where they can do damage. Its like paint on wood or varnish on a yacht, unrepaired damage will make it worse. However it does look really good.
If however you are meticulous and can guarantee every damage will be repaired immediately then do it. But for most of us paint application every few years is probably better.
4Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Wed Jul 31, 2013 9:43 pm
I will not powder coat ant part of an engine and would recommend the same for you.
Powder coating is a plastic and does not conduct heat in any real sense. Much of the cooling of even a water cooled engine comes from the airflow over the engine, if the covers have the plastic coating the heat cant escape well to the airflow.
I have seen several air cooled engines cooked and very well cooked because of powder coating the engine covers.
You may not cook a water cooled K engine but you will give the cooling system a workout that it doesnt need and reduce the cooling capacity of the system.
5Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Thu Aug 01, 2013 2:11 am
MikeP
MikeP
Paint.
I prefer paint, always and for the reasons stated.
Powder Coating Front of K engine DSCF2741-L
6Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Thu Aug 01, 2013 3:27 am
JR_K100RS
JR_K100RS
Bloody heck Mike , do you assemble silicon chips in your workshop ? Laughing
JR
Melbourne Australia
7Back to top Go down   Powder Coating Front of K engine Empty Powder Coating Front of K engine Thu Aug 01, 2013 4:27 am
Yes, er that's what mine looked like too, but the um camera wasn't working.
8Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Thu Aug 01, 2013 5:05 am
Rick G is also entirely correct re the airflow. When we did science and physics we even learnt paint colour makes a difference. The difference is slight compared to wrapping it up in powdercoating.
9Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Thu Aug 01, 2013 5:07 am
My castings are a bit off colour and am going to test cleaning them with Milton. It works for cleaning tea cups and tea spoons [a tea drinker would know how tea stains ware].
10Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Thu Aug 01, 2013 6:57 am
Powder Coating Front of K engine 2013-021
nothing wrong with a little polishing
pits and lumps present more surface area for the cooling ..so don't go overboard
paint kinda smooths this off a bit ...and powder coating adds another layer that restricts heat transfer as said earlier
11Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Sun Aug 04, 2013 1:18 am
Jim Miller
Jim Miller
Seems like a spray bomb is a hellavalot easier and cheaper...I did mine a couple months ago on the K75s and it looks like crap already..bugs and chips..
Should just paint it bug colour.
1987 K75s  and 1979 Moto Guzzi 1000sp
12Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Sun Aug 04, 2013 2:55 am
Once there is a nice coating of bugs put a coat of clear over it:D
13Back to top Go down   Powder Coating Front of K engine Empty Re: Powder Coating Front of K engine Sun Aug 04, 2013 3:07 am
Jim Miller
Jim Miller
lol!   Good one....
RicK G wrote:Once there is a nice coating of bugs put a coat of clear over it:D
