1 Temp Indication Mon Jul 22, 2013 5:35 am
Keg
Hi, I am trying to fit an aftermarket Digital Instrument cluster and have a question about the Temp Sensor setup.
The device a Trailtech Vapour Stealth seems to have a RTD style input which relies on resistance change to display temp change. On my initial searches I have found a Violet/Black stripe wire but am pretty sure this is just a switched output?.
Can anyone inform me if my assumption on the Violet/Black Stripe wire is in fact a output that becomes active at a set temp value, and if so what is the temp that the light comes on at.
Also is there a RTD fitted on the BMW K100?. I will keep searching the net but thought I would post this for some hopefully quick assistance.
