1Back to top Go down   Radiator panel Empty Radiator panel Sun Jul 07, 2013 2:19 am
Alheng
Alheng
Can the radiator screen panel be removed without removing the side lowers on an RT?
2Back to top Go down   Radiator panel Empty Re: Radiator panel Sun Jul 07, 2013 2:23 am
hmm tricky .... but should be possible
all that stuff around the forks is a pain to work at
the shroud has to come out first though .
3Back to top Go down   Radiator panel Empty Re: Radiator panel Sun Jul 07, 2013 2:57 am
Alheng
Alheng
Awhile back I reported a weep of coolant, it was never an issue and the coolant level didn't drop. I noticed just a bit of coolant stain again today and on close inspection I realise that it's weeping out of the thermostat cover. Of course that was the one o ring that I didn't change!
In the last 1000km the level in the coolant bottle has dropped 6 mm. Should I just leave it for now
4Back to top Go down   Radiator panel Empty Re: Radiator panel Sun Jul 07, 2013 3:09 am
6mm that's almost normal aspiration al (heating and cooling losses ) well during summer at least
I would plan for it sometime soon ...um before summer ...yes ?
5Back to top Go down   Radiator panel Empty Re: Radiator panel Sun Jul 07, 2013 3:24 am
Alheng
Alheng
Sounds like a plan!
