1 wiring harness swap between models Sat Jul 13, 2013 1:13 am
beanoldboy
Gday ,
The recent abay acquisition k100 has turned up a wiring harness worn through an active wire as it exits the box and ducks under the frame, some hot wires and melted insulator
So , question being, will an 84 rt harness swap and operate an 86 rt.
I see a difference in the injectors, another device on the return rail , a pressure switch or pressure transducer ? All the fuse and relay box look identical , any knowers appreciated
Ñ.
Ñ.
Last edited by beanoldboy on Sat Jul 13, 2013 1:16 am; edited 1 time in total (Reason for editing : clarity)
