1 Need help with electrical problem Tue Jun 18, 2013 10:25 pm
Puccini
When I turn on the ignition switch, the clock and gear indicator come on as well as the other lights but they are all dim.
Looks like not enought voltage.
When I hit the starter button, they all go out and you can hear relays chattering.
It looks like a load on the battery.
I cleaned the ignition switch and every connector I could find with dioxit.
Checked and cleaned the grounds.
I cleaned all the connectors on the fuel injection connector also.
The speedo shows 24,000 mi but there could be more on it.
Any Ideas???
The battery is fine. I checked it with a battery load tester.
Any Ideas???
