1Back to top Go down   Hi all,Gordon needs help Empty Hi all,Gordon needs help Sun Jun 09, 2013 2:26 pm
Gordon Smith
Gordon Smith
Although adjusting "choke" cable to its best position, it still only moves the throttle bar less than 1\2 a mill. I have studied the Haynes manual down to 4 inches square and hung on a string in the little room. NO success. Nearest BMW dealer 70 miles away. Have all the tools but need to know how. Gordon
2Back to top Go down   Hi all,Gordon needs help Empty Re: Hi all,Gordon needs help Sun Jun 09, 2013 3:46 pm
Welcome Gordon!
You find a service bulletin about this subject at the portal, look under K75 (# 2227).
3Back to top Go down   Hi all,Gordon needs help Empty Re: Hi all,Gordon needs help Sun Jun 09, 2013 3:52 pm
Gordon,
Welcome from across the sea.....Any problems everyone will help....
92KK
4Back to top Go down   Hi all,Gordon needs help Empty Part missing? Sun Jun 09, 2013 4:29 pm
ibjman
ibjman
I recently scrapped out a K75 & noted that the "choke" cable on the throttle body end utilizes a spacer washer.
Could yours be missing? Part #14 in the illustration:
Hi all,Gordon needs help B0000310
5Back to top Go down   Hi all,Gordon needs help Empty Re: Hi all,Gordon needs help Sun Jun 09, 2013 4:41 pm
Part #14 goes under the switch for the "choke" warning lamp.
6Back to top Go down   Hi all,Gordon needs help Empty Thanks Inge K. and all others. Sun Jun 09, 2013 5:18 pm
Gordon Smith
Gordon Smith
.It is the movement of the arm that the cable is connected to that is getting lost and as you cant see round the barrel I cant see how the long movement is getting lost. Although I'm getting full movement at the cable and the arm it is attached to, it is as though the other side has dropped back a quarter turn an is still moving but not cming up far enough to operate the throttles------ Any ideas?
7Back to top Go down   Hi all,Gordon needs help Empty Re: Hi all,Gordon needs help Sun Jun 09, 2013 5:52 pm
Haven't experienced any problems with this mechanism, won't be that much help.
It's a cam plate between cyl. 3 & 4, could be that it have becoming loose on the shaft?
8Back to top Go down   Hi all,Gordon needs help Empty I sent Sun Jun 09, 2013 8:06 pm
ibjman
ibjman
I sent Gordon a PM with detail photos of the part.
Like INGE says.....something could actually be coming apart? like the cam follower (roller?) on the throttle shaft could be worn through???? Or the inner lever loose damaged
Gordon may have to remove the air filter box to get a better look see
Regards......ibj...
9Back to top Go down   Hi all,Gordon needs help Empty Re: Hi all,Gordon needs help Sun Jun 09, 2013 9:08 pm
There is a small roller on the cam plate and has a screw in the centre. I have seen them come lose and fall of which causes exactly the problem you have. If you are lucky the roller will be in the muck that gathers on top of the engine.
Similar topics
» New member
