May be a K1200 as there is no shock mounting and the brake caliper mount is in the wrong place.
the.postman
bikerboy wrote:May be a K1200 as there is no shock mounting and the brake caliper mount is in the wrong place.
Yep... Looks the same as this one Here which sold for $187.50 last month
1984 srx 600
1986 cbr1000f/h
4Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty So Sun 09 Jun 2013, 13:30
ibjman
ibjman
Is it defective?
not faulty for a k1200
but for any of the earlier k bikes ...no go .....no shock mount
6Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty So Sun 09 Jun 2013, 15:06
ibjman
ibjman
So no one here has any idea what it fits???
The last of the K1200 bricks 04-05 they had no speed sender or shock mount and disc caliper are underneath but the gears fit our drives.
8Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty Outta? Sun 09 Jun 2013, 18:31
ibjman
ibjman
Outta be worth $12 huh???? If I could get it for the min bid?
the.postman
ibjman wrote:Outta be worth $12 huh???? If I could get it for the min bid?
The drain & filler plugs must be worth that !
1984 srx 600
1986 cbr1000f/h
Looks like he got an offer too good to refuse as it's finished early without bids.
ibj how much did you get it for. Very Happy
11Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty missed out Sun 09 Jun 2013, 19:50
ibjman
ibjman
I missed it. closed out before I got back to it. Someone got it for $11 (Delivered)
12Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty I would have Sun 09 Jun 2013, 19:54
ibjman
ibjman
I would have bid this but I knew nothing about it . all wanted to know what it fit, unfortunately, all the answers that came back were not the answer to the question.
Someone said it was missing something? couple of people commented but no one said what it fit.
the.postman
It's not the first time this seller tried getting rid of this.... Not sold items
1984 srx 600
1986 cbr1000f/h
14Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty So Mon 10 Jun 2013, 09:17
ibjman
ibjman
So thanks a lot for all the info.
Seems like although it had been dirt cheap, there's really no reason to buy it. The later K's that it did fit had a six speed, right? Since it's a 34/13......even though the gears might be useable in the early K the only person who would want them would be someone wanting to modify for a drag racing machine, huh?
Still, it looks like the U-joint alone could be a benefit for someone, someday?
It still puzzles me to determine if they pulled it too soon or if I just screwed up & missed it.
Also......something else strange is that the girl that had it, had nothing even closely related to it in her "other items".
Also, in her relatively few "negative comments" she had a couple of unusual posts.
If it comes up again @ .99 plus shipping shall I snag it??????
Jman
15Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty I'll have to figure this out too Mon 10 Jun 2013, 09:19
ibjman
ibjman
Interesting observation Postman! I'll have to spend some more time fishing around ebay to learn how you pulled up/found all those previous sales on the same part??????
I wasn't aware of how that works!
Thanks, ibj...
the.postman
ibjman wrote:Interesting observation Postman! I'll have to spend some more time fishing around ebay to learn how you pulled up/found all those previous sales on the same part??????
Thanks, ibj...
Just look at "sellers other items" then scroll down the left hand side and click "completed listings" then just searched for BMW
1984 srx 600
1986 cbr1000f/h
CommanderKewl
CommanderKewl
I bid on it and it was IMMEDIATELY PULLED from bidding.hmmmmmmm.
18Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty very interesting Mon 10 Jun 2013, 18:27
ibjman
ibjman
That seems to clarify a lot!
My information from ebay seems to indicate that once a bid is actually received, the seller can no longer edit the posting. I'm not sure if that includes pulling it??
Did you actually see your bid show up on the page before it was terminated?
I can't coment on it from a US law point but in Australia if you put something up for auction and it only gets 1 bid of a dollar for a new car then you have to sell it to them if you didnt have a reserve. But ebay is not legaly an auction because the agent can only act for the seller and not the buyer and ebay does both so its a very tenuous situation you can find your self in when someone pulls the item 2 minutes before the end.
It sure is dirty tactics with that drive and has apparently been done before. Commander I would have a word to ebay and tell then what happened and they may take your side. In Australia they more often than not take the side of the buyer.
20Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty Our In-famous rear drive Wed 12 Jun 2013, 10:11
ibjman
ibjman
Well I just put a bid on it and if he pulls it again I will have a lot to say to ebay about it.
22Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty so,, Wed 12 Jun 2013, 17:11
ibjman
ibjman
You just buying it to get the gearset out of it or will you re-sell it?
The gear set more than anything but if you want it I only put $20 as a Max and wont go higher if you want it
24Back to top Go down   Cheap 34/13 Final drive on Fleabay Empty nope Wed 12 Jun 2013, 17:21
ibjman
ibjman
Nope, don't want it.
But the 34/13 gearset might be the hot tip for the chair rig????
I'm wanting to go the otherway with my rs.......the gearset fromm an r1200c and the transmission from a K75 would give me the highest possible gear combo........correct?
I already have the k75 box in my stockpile unless someone buys it from me
With a K75 box you will be about 70rpm higher at 60mph so that wont help.
And I intend to do some more investigation into the different gearing of the K75s 5th gear as I was working out ratios a few days ago and the gears would need to be very different in appearance than the K100 (as in much finer teeth) to get the ratio quoted.
I think someone made a mistake with some numbers at BMW and the myth has kept going because I am sure that when I rebuilt the gearbox in the K75 I used the original input shaft and the rest of the inards of a K100 box that had a shagged front spline.  Now that would be impossible if the ratios were as I have seen quoted in the factory literature.
Last edited by RicK G on Wed 12 Jun 2013, 17:33; edited 1 time in total (Reason for editing : cant spell and cant type)
MikeP
MikeP
That differential gear set was first used on the K1, then subsequently on the K1200 (and IIRC the K1100LT in some markets to give 5th more of an "overdrive" ratio).
