I'm sorry if this is a repeat thread from somewhere else on the site.
I've just done the shims on my 8v RS and that's all good. But the shim kit I have responsibility of(not mine) is drastically in need of certain shims and has an abundance of others.
I need some 2.35s, some 2.50s, some 2.55s and some 2.60s.
I have an abundance of 2.65s.
Anyone interested?
'93 K1100LT
valve shims for an 8valve 100 or a K75 (swap) K-dogs10
perhaps a Sydney maintenance day would be in order where we could;
check tolerance of valve settings which may allow a swap to reset the shim count....at the very least it would show if shims need to be purchased....
What do you think?
KKlompy valve shims for an 8valve 100 or a K75 (swap) 2854237993
valve shims for an 8valve 100 or a K75 (swap) Au-log10
I have a few 255 and 250 that are excess but only 1 235. I will bring some down in sept and do some heavy wheelin and dealin.
I can post if you want then sooner.
BTW now that I have done a head reco on my K11 I may be needing some 16v buckets do you guys have any of those.
RicK G wrote:I have a few 255 and 250 that are excess but only 1 235. I will bring some down in sept and do some heavy wheelin and dealin.
Having just done the shims on my 1100 I have a few leftovers.
2.95 x 1
2.90 x 7
2.75 x 1
Speed isn't important on the others, I haven't got anybody looking for them at the moment but I've got none of those sizes (its the clubs shim kit, I just look after it). The factory kit contains 4 of each size, I topped it up a few years ago with a bunch of Yamaha XJ shims.
Looking like there could be a mini swap meet too!
'93 K1100LT
Klompy the grey brick wrote:perhaps a Sydney maintenance day would be in order where we could;
What do you think?
That's a good idea, just have to find out who's interested. I've got the shims, the tools and a set of mercury sticks for throttle body synch. Some people might need a set of cam cover gaskets if they've hardened up too much, mine were very borderline today.
'93 K1100LT
I'm very interested, would like to learn how to d shims.
2.95 x 1
2.90 x 7
2.75 x 1
I'll keep those in mind AL if I need any of the sizes I have all 16 from the second head and havent been through them yet.
The head I am using had all 285 or 290 in it and one was a bit iffy with some case hardening starting to flake.
Yep I am up for it...so I need some gaskets "just in case"...orings too?...for the bolts...will check Motobins or Motorworks.....perhaps in a couple of weeks??? have heaps of room here and secure enough to leave stuff lying around.
Klompy the grey brick wrote:Yep I am up for it...so I need some gaskets "just in case"...orings too?...for the bolts...will check Motobins or Motorworks.....perhaps in a couple of weeks??? have heaps of room here and secure enough to leave stuff lying around.
2 weeks is the Casper Rally for me, but 29/30 I'm clear.
The bikes need to be cold for clearance checking so some time is required even though it's a fairly easy job. The rubber gaskets get less flexible with age so it's a maybe. Mine have sealed OK with a smear of silicon. I've had few overheating episodes which might have had some effect on the gaskets too.
'93 K1100LT
lets book it in Eddie...venue optional in locality....TBA
gpguyer
gpguyer
Klompy let me know when and I will try and get down.
Gordo.
I have many 2.55 and 2.65 shims, will swap for almost anything.
I desperately need some 2.60 shims(have none left), also need to top up 2.25, 2.3, 2.35, 2.4(one left in the kit)
Time for another valve clearance day?  Sydney or Hunter?
'93 K1100LT
