1Back to top Go down   negative battery cable Empty negative battery cable Thu May 30, 2013 11:28 pm
IDTWIKA
IDTWIKA
I took the old battery out last month to replace and for the life of me I can not remember where the negative cable connects to ground on the 91 K100 LT bike. I have looked at trusty Clymer's but to no avail.
Any help out there?
2Back to top Go down   negative battery cable Empty here Fri May 31, 2013 1:10 am
ibjman
ibjman
9cm (3 1/2") directly above the transmission shift shaft on the left side of the transmission
3Back to top Go down   negative battery cable Empty Re: negative battery cable Fri May 31, 2013 1:50 am
just make sure it is clean and the bolt is not corroded
this cable is a prime candidate for an "upgrade " if it is the stock unit . there are better !
