1Back to top Go down   Front fork. Need help! Empty Front fork. Need help! Wed Jun 05, 2013 4:35 am
metalist2006
metalist2006
ask for help. When collecting forks one feather stuck, I can not get a polished piece. I think that straightened the ring and it's impossible to pull the pen. What to do?
BMW k100rs 04/91
*-=o2o3o33=-*
2Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 4:41 am
Your translate did not work
3Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 7:48 am
metalist2006
metalist2006
Sorry for my English, was in the garage wrote off the phone. I tried to change the oil seals, finished the right pen. With the left came out the problem. I think is bent on liner pen. He circled in red. Can't parse left feather,I removed the retaining ring, gasket, the steel ring. But the polished piece of shock absorber does not come out of the bottom. How to be?
Front fork. Need help! 01c1deedf4bd
BMW k100rs 04/91
*-=o2o3o33=-*
4Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 8:18 am
Can you turn the chrome tube in the bottom part?
5Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 10:44 am
metalist2006
metalist2006
tried the heat ... but failed to pull out the cartridge.
She has a stroke of about 15 cm, also detail easily rotates.
tried to depict the figure. the service does not offer a guarantee that will gently take apart shock absorber. any ideas are welcome.
Front fork. Need help! C367c38b563e
BMW k100rs 04/91
*-=o2o3o33=-*
6Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 10:46 am
Have you removed the bolt at the bottom of the fork leg where the axle is.
8Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 11:41 am
metalist2006
metalist2006
RicK G wrote:Have you removed the bolt at the bottom of the fork leg where the axle is.
yes of course. With the right pen I'm done. All that can be removed I did.
BMW k100rs 04/91
*-=o2o3o33=-*
9Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 12:11 pm
metalist2006
metalist2006
I wanted to make a record of the work done, but there was a problem. Once I decide a question here in the description to a photo. I did everything step by step and without haste. When assembling the left pen cartridge problems began, not sat on the left 2 cm before the end and stuck. Not inserted until the end and did not go back, stuck in the end.
Front fork. Need help! A051c3d746db
Front fork. Need help! 11bd53e47c50
Front fork. Need help! 52d7288d4e39
Front fork. Need help! 523721ae1740
Front fork. Need help! 84d138d162ed
Front fork. Need help! 6eff73052cfd
Front fork. Need help! C824736b9f95
Front fork. Need help! 584527640fa0
Front fork. Need help! 0bc2e81dcb49
Front fork. Need help! D881f7d463cc
Front fork. Need help! D888877fc478
Front fork. Need help! Da1558be6a17
Front fork. Need help! 5240474f4f20
Front fork. Need help! 7e1ee273caec
Front fork. Need help! 35fc44ebedc5
Front fork. Need help! 6f34785a8662
Front fork. Need help! 965e27014da2
Front fork. Need help! 446052b81f92
Front fork. Need help! Cf11e147c0b4
Front fork. Need help! 7b8ad8400921
Front fork. Need help! 013056f3e38a
Front fork. Need help! Ff3063c94f15
Front fork. Need help! 81b8d59fd6ce
Front fork. Need help! 0540d6d8401a
Front fork. Need help! 254885dcfc71
Front fork. Need help! 02565561a4b9
Front fork. Need help! C4d1af845f0b
Front fork. Need help! Fa4c743b8368
Front fork. Need help! 6a85c890f6a6
Front fork. Need help! 15b635f0e174
Front fork. Need help! D43cff1d2e84
Front fork. Need help! 5beb14da1f3f
BMW k100rs 04/91
*-=o2o3o33=-*
10Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Wed Jun 05, 2013 10:19 pm
If you can get the tube out then check it is straight and check the alloy slider for impact damage.
A word of caution. "Pyramid Parts" are junk and should be avoided. I used Pyramid Parts seals and they failed within 2000km. We have found that the BMW seals are the best to use.
11Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 12:12 am
beanoldboy
beanoldboy
metalist2006 wrote:When collecting forks one feather stuck, I can not get a polished piece. I think that straightened the ring and it's impossible to pull the pen.
This months secret Cool front door pass-phrase.
N.
http://www.airware.com.au
12Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 4:51 am
N.
Only when you are pissed. Ala Beerfest.
13Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 6:39 am
LifeGuard
LifeGuard
RicK G wrote:...We have found that the BMW seals are the best to use.
True, I can confirm that.
BMW seals cost 3 times of some no-name scrap. But this very acceptable cost.
http://tchorzewski.net
14Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 1:03 pm
metalist2006
metalist2006
I won. you only replace the guide bush and ready to assemble the.
Front fork. Need help! E450e4a34fd3
Front fork. Need help! E3ad57581c50
Front fork. Need help! C3a15a2e5d19
Front fork. Need help! 93164f292e17
Front fork. Need help! 02814c9705fd
Front fork. Need help! 9bbebed8f80f
guide bush unbent and prevented the movement of the shock absorber. With the hammer back, knocked out. no visible damage, operation will tell. :|
Assemble will be more photos if interested then I do. Very Happy
BMW k100rs 04/91
*-=o2o3o33=-*
15Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 8:24 pm
beanoldboy
beanoldboy
The photos are excellent thank you metalist2006, I'm interested and these entries will serve well as learning resource material into the future.
Good work mate .
16Back to top Go down   Front fork. Need help! Empty Re: Front fork. Need help! Thu Jun 06, 2013 9:45 pm
Good that you found the problem. Is the internal surface of the slider still good. I hope it is. Front fork. Need help! 112350
