1 1986 K100 cold start issues Sat May 25, 2013 2:33 am
Good morning ladies and gents,
Concerning the above, I've run in to an issue when trying to start my bike.
Basically, once the engine is warm, I can look at the start button and she fires right up, however, when she's cold, she just won't start without a massive amount of fettling.
My approach has been to swap known good parts for those on the bike, which has included the following: Fuel pump, HT leads, coils, fuel filtre, air flow metre, adjusting the throttle position sensor, and choke set screw, as well as checking the air/fuel with an exhaust gas analyser. Sadly, none of these things have made any difference at all, so I'd greatly appreciate the input of your collective wisdom.
Cheers, Alex.
P.S. I have the same problem on the other 1986 (Victoria Police restoration).
Cheers, Alex.
