1Back to top Go down   Gear selector indicator sender Empty Gear selector indicator sender Tue Sep 10, 2013 7:16 am
harrowbmw
Greetings people.
Some time ago I had the chance to replace my gear selector indicator switch.  You know, the one that sends the signal to the LCD display in your instrument pod.  The little sender unit is attached to the back wall of the gearbox in K100's and most likely K1100's too.  During the job I took detailed photographs and have collated them in a file in the hope they may help someone else new to the job.
Don't hesitate to contact me should the need arise.
Cheers and kindest regards
Paul Harrington
Australia
E:  corcaigh@internode.on.net
2Back to top Go down   Gear selector indicator sender Empty Re: Gear selector indicator sender Tue Sep 10, 2013 9:33 am
Thats good of you Paul, give Crazy Frog a PM and see if he wants to include it in the downloads section.
If it is put there it doesn't rely on our failing memories as to who in the hell had a write up on that.
