1 Just an update Sun Apr 28, 2013 10:14 pm
ibjman
Hi Ya-All,
just got back from a weekend trip from Phoenix, AZ to Laughlin, NV (BIKE WEEK). To meet up with Family & friends. This is mostly a Harley event, but all makes are always welcome!
I experienced 2 minor inconveniences. On Saturday morning when departing with Family & friends for a tour tip to visit Oatman, AZ, My wife & I had just turned onto the street from the parking lot when the throttle stayed on a very "high idle" & refused to idle down despite multiple attempts to blip the handlebar twist grip......just stuck there about 2500 - 3000 rpm. After shutting off, several turns of the throttle revealed that the throttle body springs appeared to be correctly pulling the cable back toward idle normally.......no unusual slack in the cable feel at the twist drum. Hmmmm.... Only after cycling the fast idle choke lever a couple of times open & closed, did normal operation resume.
Worked fine the rest of the trip. No attempt to repair or evaluate has been started. I am assuming that after extensive electrical & fairing work last week, that a piece of foreign material must have fallen into the area of the fast idle mechanism & jammed it until it finally fell through. I expect that next week when I pull the left dash trim & the left lower fairing, that I'll find a piece of "flotsam" laying on the top of the cyl head below #4 TB.
Second item of consternation was that before leaving, I spent a lot of time adding an Eastern Beaver light relay kit complete with HD ceramic connector plug, attached to an 80/100 Headlamp bulb. Everything seemed fine. This morning before leaving Nevada, I noted that the low beam was dead. Getting around front, I tested the High beam & watched the whole housing fill with smoke as the high beam burned out.
Having now driven home, I note that there's pieces of glass laying in the bottom of the headlamp housing from the shattered bulb. I'm now faced with no alternative than to pull the whole fairing loose again so I can get the housing out to clean & inspect the inside. I'm at a loss to understand why my new bulb shattered. It ran well for 6 hours or so & I was doubly sure not to touch the glass of the halogen bulb when installing it. I'm guessing that it had to have had some event where it collided with some part of the reflector or deflector on the bumpy road.
Any ideas?????
Anyway, Our side trip from Laughlin, NV to Oatman, AZ went off well. Oatman is a quirky little rural mountain town that's a favorite tourist destination The big attraction there is that there's a number of wild burros (Donkeys) that have free rein of the town. they wander about at will, are very tame. This weekend, Oatman was an absolute ZOO with all the Harley folks and 1 or 2 lonely BMW's. Here's a few pics:
Any ideas?????
