1Back to top Go down   Fuel Sensor. Empty Fuel Sensor. Sun May 05, 2013 10:26 pm
Passion85
Passion85
Hello all,
I've been working on the Fuel system on my 85 K100 for a while now. Managed to replace all of fuel lines fuel pump and damper and several other things. I got everything back together and the pump started working when i realized I had hooked up the leads wrong. So I took everything apart and switched the leads. Put it all back together and nothing... I started checking if I was getting electricity to the pump, I wasn't, I unplugged the fuel sensor and tested it, it was getting electricity. So I have narrowed it down the the fuel sensor. I did a short look online to see if I could find a fuel sensor and didn't come up with anything I haven't even been able to come up with a part number. Does anyone have any suggestions on how I could remedy the situation.
Thanks,
Passion85
[img]Fuel Sensor. 20130520[/img]
2Back to top Go down   Fuel Sensor. Empty Re: Fuel Sensor. Mon May 06, 2013 4:38 am
daveb
daveb
hi
I had to replace the exact same on my 85 k100rt
look at www.motorworks.co.uk
I dont think you can get new ones but they are under
used fuel level sender early part no TAA59448
£35
hope this helps
Dave
3Back to top Go down   Fuel Sensor. Empty Re: Fuel Sensor. Mon May 06, 2013 6:44 am
Can you modify the fuel sensor to just send power to the pump: Removing the electronic and wiring the pump directly.
The Green/white wire is the positive, the brown the negative.
Brown/black and brown/white are for the fuel level sender.
CF
Fuel Sensor. Frog15Fuel Sensor. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Fuel Sensor. Empty I have a used one Mon May 06, 2013 10:41 am
ibjman
ibjman
I have a used one from an 85 K100RT (if I can find it). $25.00 delivered to your door. (Sorry, it won't fit in the smallest flat rate box)
