1 Neutral light gets lit when the 4L fuel reserve sensor kicks in Wed May 04, 2016 8:34 am
lalilulelo
Dunno if it is the best topic describing the issue but i'll try my best to explain it here. I've stumbled upon this great community and have presented myself : https://www.k100-forum.com/t11150-new-member-in-sweden
Hopefully someone can help with this small issue
So im making a cafe conversion of my K100 and the frame was dissasembled for repainting a while ago. I've reinstalled the frame and the bike is almost done. I connected the original speedometer (breadbox) since i could only start the bike with the clutch hold in to see if the neutral light on the original speedometer would get lit.
That was not the case, the neutral light on the original speedometer only gets lit when i tilt the gas tank backwards (probably the 4L reserve fuel sensor) and its only when the gas tank is tilted backwards i dont need to hold the clutch to start the bike.
My guess is that something somewhere is not connected correctly, where it is i dont know, all of my other lights work (turn signals, rearlight, headlight etc). I've tried to locate the problem with no success, still the same error.
I bought a BEP 2.0 and going to also buy a control light unit from daytona, would be nice to be able to use all of the 5 lights on the control unit. It is not the biggest issue in the world, the bike runs eitherway but it would be nice to have a working neutral light and a 4L reserve fuel indicator instead of having a neutral light that gets lit when the gas tank is on the reserve.
Thankful for any kind of feedback and help.
