sparkplug wrote:At the risk of reviving an old thread
I did a search to see what solutions people have to mount GPS on a K100RT.
Funnily enough I had also looked at the hole on the bars and thought that it must be possible to RAM mount something through that - but cable routing would need to be done carefully as this will move every time you turn.
Just wondering what others have done
Thanks in advance
Hi Sparkplug,
Most GPS mounts I have seen go on the bars - but being a purist, I don't like the off-set look that mounting on a K100 gives. Call it feng shui, call it ocd, blame it on me being born under the star sign libra or call it what ever you like...but I like balance and things looking right.
I have a Garmin Zumo 590LM (which is one of the larger bike GPS's - roughly 150 x 100mm and weighing in at about 375g) and I successfully mounted it on the dash/crash pad in the centre between the 4 auxiliary switches using the power supply mount and the RAM fittings that came with the GPS. Incidentally, the cost of this GPS is frightening and I have just forked out nearly £100 to buy a new motorbike mount and RAM fittings to enable me to use the GPS on either Heidi or Gretel. However, I have been very pleased with the performance of the GPS (now that my wallet has recovered).
Easy enough to fit - drilled two holes through the rubber of the dash/crash pad and fitted long bolts through from the inside (need to unbolt the dash/crash pad to get the bolts through, but no need to disconnect any of the switches). Then a simple case of running the wiring down under the fuel tank (tank off job) to hook up to a suitable permanent power supply.
The end result is nice and central, the GPS does not obscure the instrument cluster and the auxiliary switches are easily accessible over the top of the GPS. It seems to support the weight of the GPS well enough and as a bonus, it doesn't sit directly in your line of sight to cause a distraction while riding - but is easy enough to see with a quick glance down.
Obviously this set up no good if you want to use a tank bag.
Anyway, a few pics of my set up...as fitted to Heidi.
My next "upgrade" victim - Gretel
Ringfad - I think you are replying to an 18 month old post.......
