1Back to top Go down   A question or two ? Empty A question or two ? Mon Apr 08, 2013 1:33 am
DeRodster
DeRodster
Can someone tell me how would I know if I have heated grips (yes I know ....turn em on) , and how do I turn hazard flasher on.
I have switches for both but not entirely sure if there is anything attached to the switches.
also what mount is recommended for gps.
Rod
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 1:56 am
DeRodster
DeRodster
ok heated grips are working as far as I can tell. I guess I wasn't giving them enough time, or maybe the batery was down a bit.
nothing happening with the ''hazard's'' though.
Ign on, hit the switch....nothing.
Indicators are working ok.
Idea's please
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
3Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 4:22 am
as usual rod, the flashers switch usually suffer from corrosion across the switch contacts .
take the switch out and clean it up ?
there are a few threads on gps mounting ...have you tried the search feature ?
4Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 6:11 am
DeRodster
DeRodster
Good point, i'll give that a go.
No i never thought of searching here, I did find ''RAM mounts'' on Google though.
Guess its just a matter of deciding what you want and where you want to put it.
Mounting on the brake reservoir cover seems neat.
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 6:21 am
DeRodster
DeRodster
re Hazard switch repair / clean....
https://www.k100-forum.com/t4717-hazard-switch
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
6Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 9:16 am
Try one of these, a friend has one and says how good they are but I have not seen it yet.
http://www.semsons.com/meunmomimowi1.html
7Back to top Go down   A question or two ? Empty Re: A question or two ? Mon Apr 08, 2013 6:43 pm
AJ.Valente
AJ.Valente
Emergency flashers only work with the engine running, although they'll remain on after the engine is shut off (but this is a major battery drain, so be forewarned).
8Back to top Go down   A question or two ? Empty Re: A question or two ? Tue Apr 09, 2013 6:48 am
GPS holder, Tomtom Rider mk.I, K11LT.
A question or two ? Hpim0810
9Back to top Go down   A question or two ? Empty Re: A question or two ? Tue Apr 09, 2013 9:50 am
Is that picture of your K1100 Inge. It has a very different speedo face to mine, were they different from 94>.
