1 Air leak, fuel pressure or electrical with poor starting? Thu Apr 04, 2013 10:16 am
colinijohnson
Could some kind soul suggest on the balance of probabilities where to check next? MY 1989 LT starts on the button when warm, but I have to feather the throttle when cold(white smoke) and give her lots of revs before she will idle ok - I suspect it's effecting my mpg as the red light comes on at 150 UK miles (241km).Bikes on 32k miles, sounds turbine great.
Main jobs done (by my mechanic who is ex BMW) over the past 2 years.
Recon injectors fitted, new exterior fuel lines, tank clean & filler cap(crudded up), Major service inc valve check, plugs, filters fuel. New battery & uprated earth kit. New ramspeed ht cables(these make a big difference, only £50). New crankcase breather hose(was cracked).New temp sensor near radiator. New oil/water pump fix kit (was very worn), new tps switch (old one failed)..
I also cleaned all undertank contacts including the ignition unit and treated - EXCEPT the relay box & computer. (The computer connections look tight and well greased - but I didntnt open it.
I've also had the clutch & suspension upreated,exhaust gaskets renewed, handlebar rubbers, front brearings... so spent loads of £££, - just need to address the starting issue!!
From reading posts - my suspicions are
Many thanks
Colin
- Poor contacts inside computer/relays (my seat is worn and holding water!)
- Blocked fuel regulator (I had problem with dirty filler cap/fuel filter and may be a blockage??)
- In tank fuel lines worn
- Worn throttle body rubbers (my mechanic says they are ok as all is balancing fime when injectors replace)
- Any other worn rubbers?
- Hall sensors or their contacts
- All of above!! (my mechanic is very good - but not an owner)
Many thanks
Colin
Last edited by colinijohnson on Thu Apr 04, 2013 10:18 am; edited 1 time in total (Reason for editing : spelling)
