1Back to top Go down   Engine dimensions Empty Engine dimensions Wed Mar 27, 2013 7:02 pm
blimp
blimp
Hi, can anyone tell me the measurements of a k100 or k1100 engine.
From the sump to top of cylinder head
From timing case cover to the join with gearbox.
Also, the diameter of the clutch disc, not the friction plate, but the outside diameter of the cover plate.
Many thanks in advance.
2Back to top Go down   Engine dimensions Empty Re: Engine dimensions Wed Mar 27, 2013 10:41 pm
Length 502mm Width 498mm Height 410mm and clutch is 210mm
Hope that helps
3Back to top Go down   Engine dimensions Empty Re: Engine dimensions Thu Mar 28, 2013 10:49 am
blimp
blimp
Many thanks.
