Rendrag
Rendrag
So, gearbox is finally back together, would have been a simple job if I hadn't swapped the shells for the input shaft bearings over. Took her for a test ride, and holy stuff, it's beautiful! No gearbox noise, it snicks into gear with almost no gear lever movement, it's just perfect!
Except, when I got home, I had oil all over the swingarm and tyre!
Getting under the bike, it looks like it's coming out the boot that the clutch actuator goes into? when assembling it, I notice that there was a seal in the end of the input shaft, so oil couldn't go up the shaft towards the clutch.. But I couldn't for the life of me see what stopped the oil coming out the back.. Is it expected that the friction fit for that big cylinder of aluminium (the parts diagram calls it a piston) will stop the oil? Or did I miss something important there somewhere???
Dammit, so wanted to ride to work tomorrow!!
2000 VFR800
The boot is what stops the oil coming out. If the actuating arm isn't adjusted correctly then the boot leaks around the adjusting bolt. Or needless to say if the boot has not gone on straight and its leaking there.
Rendrag
Rendrag
Rick G wrote:The boot is what stops the oil coming out. If the actuating arm isn't adjusted correctly then the boot leaks around the adjusting bolt. Or needless to say if the boot has not gone on straight and its leaking there.
Thanks Rick, yeah I realised that after some searching.. Will replace the boot just to be sure (it's been taken off and put back on four occasions now..), but i discovered that all that oil came out of my 'new' shock, not the gearbox! Was sitting there looking at the bike in dismay, then went 'hang on a minute, why is the oil BLACK?? It's only done 5km! Swapped the koni for my normal shock, degreased the bike, and went for another ride, and it's all perfect Smile
Tell ya what, I should have rebuilt the gearbox earlier - it's so quiet, and gear changes take so little movement!!
Though I might keep an eye out for a new selector drum - it's still very notchy between first and second, where all the damage on the drum is!
2000 VFR800
