1Back to top Go down   Final Spline Replacement Empty Final Spline Replacement Tue Mar 05, 2013 3:40 pm
K100LT Notts
K100LT Notts
I have just lubed my splines - first time I have done it. Thanks for the guidance on this forum. I took these pictures of the splines after cleaning and before adding the lude (A molyslip grease donated from my local BMW dealer!).
But will they last?
https://plus.google.com/photos/108070380341695510358/albums/5851943418515847377?authkey=CKq75cC074O_7AE
2Back to top Go down   Final Spline Replacement Empty Re: Final Spline Replacement Tue Mar 05, 2013 5:46 pm
twincarb
twincarb
I can't see your pics however motorworks or motobins will sort out for a reasonable sum a repair to your final drive. I had mine done and the turn around was pretty good I have had no problems since Very Happy
Yamaha Thundercat
Final Spline Replacement 169042Final Spline Replacement 169034
3Back to top Go down   Final Spline Replacement Empty Trying to get Picture to Link Tue Mar 05, 2013 5:57 pm
K100LT Notts
K100LT Notts
I am not sure how to link my original post to pictures in my Google+ photos. I have editred the original post to link. Hope it now works.
4Back to top Go down   Final Spline Replacement Empty Re: Final Spline Replacement Tue Mar 05, 2013 6:16 pm
twincarb
twincarb
Nice bit of saw tooth action going on there.... I am by no means an expert but I would say keep a close on them. The ones on the driveshaft itself tend to go before the final drive side.
Yamaha Thundercat
5Back to top Go down   Final Spline Replacement Empty Re: Final Spline Replacement Tue Mar 05, 2013 7:20 pm
frogy
frogy
Yep,its whats called the mountain peak.Lucky never to have that problem,but that is what you will see when going,going,gone.
6Back to top Go down   Final Spline Replacement Empty Re: Final Spline Replacement Tue Mar 05, 2013 7:29 pm
They are both shagged, with some good moly grease they will go a bit futher but if they were mine I would not even consider riding till fixed. Once the spline on the drive goes it probably cant be repaired but can now. As for the shaft get the weld on spline from Motobins and any good engineering shop should be able to do the job.
