1Back to top Go down   Greetings from Notts Empty Greetings from Notts Thu Apr 18, 2024 8:16 am
Juperwort
Juperwort
Hello. New owner here. I got a boot load of parts that mostly adds up to about 75% of a 1986 K75s in poor shape.   Be interesting and fun to see how it builds up. All done on the cheap in a cramped garage with four stable mates
Frame has been blasted and painted.
gearbox back attached to engine
Now a rolling ish frame, bar front wheel on as needs a new tyre valve.
Wiring looking sort of on, but have noticed a few connector differences. Mainly being the ignition key although BMW wiring, seems to have a flat rather than round connector. Oil temp single wire has a mismatch between flat and round pin too. and little bits like that.
Need some K75 s bars too, but only seem to see the high ones on eBay etc
Will probably return with some pics if you want, and maybe some wanted's.
JW
2Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Thu Apr 18, 2024 9:50 am
Greetings from Notts 177912 The K75 guys will be along shortly.
3Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Thu Apr 18, 2024 3:28 pm
bad boy
bad boy
hello Juperwort
Cheerz, David
Greetings from Notts 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
4Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Thu Apr 18, 2024 3:48 pm
Welcome too.
But I am going to upset you a tiny bit since you have it in bits.
When you put the gearbox back on, did you do any assessment of the crankshaft rear main seal? Those are a well known fail point and they are cheap as chips if you have the gearbox off the engine, just the seal and O ring and some clutch bolts. If it has been sitting in a box for a few years its a high risk fail item.
5Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Thu Apr 18, 2024 3:49 pm
The doctor
The doctor
Hi Juperwort
from another K75s owner  Greetings from Notts 177912
I suffer from Cyclonic irritation
K75s
Buell M2
Suzuki TL1000s
Honda NS400R
Honda VF500F2
Honda CB200
6Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Thu Apr 18, 2024 9:04 pm
Dai wrote:Greetings from Notts 177912 The K75 guys will be along shortly.
You called?
If it is a 75S that you have then K100RS bars are the same.  Have a look at Motorworks if you are chasing second hand parts in the UK.  They also have new as does Motobins.  Both companies have good reputations.
Oh, and Welkom.
7Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Fri Apr 19, 2024 10:11 am
grosbeak
grosbeak
Greetings from another new K75 owner in Ottawa, Canada!
1992 BMW K75S 0212025, 1999 Suzuki Bandit 1200 2100162
8Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Fri Apr 19, 2024 10:57 am
Juperwort
Juperwort
Thanks All. Gearbox seal was good, and looked new. Clutch o ring replaced, new gearbox bolts. Just tested the radiator, holes galore!
9Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Fri Apr 19, 2024 4:17 pm
Juperwort wrote:Thanks All. Gearbox seal was good, and looked new. Clutch o ring replaced, new gearbox bolts. Just tested the radiator, holes galore!
But the crankshaft seal? They will all look new too, unless the PO did it while he had it apart?
10Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Sat Apr 20, 2024 7:37 am
td5
td5
Welcome from down under, send the pics, plenty of experiance here just ask.
Greetings from Notts K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
11Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Sun Apr 21, 2024 7:17 am
Bernie_K100
Bernie_K100
Hi,
Greetings from Notts 177912 to our community!
Bernie
12Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Sun Apr 21, 2024 9:49 am
fishboy316
fishboy316
Hello!
13Back to top Go down   Greetings from Notts Empty Re: Greetings from Notts Mon Apr 22, 2024 4:31 am
Juperwort
Juperwort
sorry, I meant the crank seal. Was all dry and relatively clean. I hope the new looking seal, was new
