1 Front forks mudguard mount bolts Sun Feb 24, 2013 5:21 pm
Fentible
Ive acquired a set of K75 'S' type forks to fit to my K100. Before I resort to drilling out, can anyone tell me if the mudguard mounting bolts are threaded through the fork slider lugs or simply push through?? Ive got the forks separated but can't remove these bolts. There is a fair bit of corrosion sealing them in and despite copious quantities of heat and anti-sieze fluid all Ive suceeded in doing is rounding the internal allen head hex on one of the bolts.
I removed one of the mudguard bolts on the forks currently fitted to my K100 quite easily and they are push fit through the mounting lug. However these are non standard hex head and have clearly been replaced at some point so I don't know if the originals suffered the same fate and were drilled out. In any event I tried replacing the nut to the exposed thread and tentatively thumping, to no avail. If I though they were a push through fit I might try a firmer thump.
Fent
Fent
