1Back to top Go down   If only..... Empty If only..... Wed Feb 20, 2013 8:48 pm
electric_monk
electric_monk
2Back to top Go down   If only..... Empty Re: If only..... Wed Feb 20, 2013 9:01 pm
seems a little pricey when I have seen how well others on here have done....is it special materiel or extra light due to thin wall tubing etc ...
KKlompy If only..... 2854237993
If only..... Au-log10
3Back to top Go down   If only..... Empty Re: If only..... Wed Feb 20, 2013 9:02 pm
It's a place to start but wouldn't be much good without the accompanying bodywork. Cool stuff though.
4Back to top Go down   If only..... Empty Re: If only..... Wed Feb 20, 2013 11:33 pm
It doesn't really describe the actual improvements or advantages of the frame there. Presumably a stiffer steering head area...though the rear section looks a bit spindly. Does it give great all-round rigidity? More ground clearance? Is there an inherent problem in the stock K frame or would we be paying 2 grand for a pseudo " Monstro" frame? Looks cool though...:-)
Sean.
5Back to top Go down   If only..... Empty Re: If only..... Wed Feb 20, 2013 11:46 pm
I have built a few frames and that will crack along the tube at the arrows between where the other tubes are welded to it. Should have been a bent tube where the red line is.
If only..... 4ea5e410
