1Back to top Go down   1984 bmw k100 centre stand Empty 1984 bmw k100 centre stand Sun Aug 16 2009, 01:32
gabriel
Hi everyone
I'm enquiring about a replacement centre stand for a 1984 bmw k100.
My question is are the later type centre stands (the ones with the straight ends) interchangeable with the 1984 model (the stand with the curved ends). and iif so, do i need to replace the support plate?
There is a photo and description of the centrestands on the Motobins website.
regards
gabriel
2Back to top Go down   1984 bmw k100 centre stand Empty Re: 1984 bmw k100 centre stand Sun Aug 16 2009, 03:59
ReneZ
ReneZ
If your stand support plate hasn't been exchanged earlier, then you should do it now. Early one was a rectangular shape (4 sides to it), newer ones a U shape. The newer style stand doesn't fit the old support plate. They both bolt into the same holes in the gearbox, so it is an easy change. Does that answer your question?
Rene
BMW K100 - 1985 (0030029) Scotland 1984 bmw k100 centre stand Rain
3Back to top Go down   1984 bmw k100 centre stand Empty Re: 1984 bmw k100 centre stand Sun Aug 16 2009, 04:45
phil_mars
Hi Gabriel I have just ordered one from Beemerboneyard that comes with the new support plate so I will try and post the results.
Motobins advertise the stand separately and Beemerboneyard sells them collectively for an equivalent price (when in stock).
I would have tried what you are querying but now should not have to worry and based on Rene's suggestion I would have had to order a separate plate anyway.
Phil
