1Back to top Go down   Ignition coils Empty Ignition coils Fri Apr 28, 2023 3:34 pm
Chris Garrard
Chris Garrard
Hi out there. I'm in the States and having a hard time tracking down some ignition coils for a 1985 K100. The supply has dried up, but someone knows where they can be obtained. Thanks
2Back to top Go down   Ignition coils Empty Re: Ignition coils Fri Apr 28, 2023 4:02 pm
4Back to top Go down   Ignition coils Empty Re: Ignition coils Fri Apr 28, 2023 10:51 pm
Bricklayer
Bricklayer
I used a set of these with great results:
Premium Quality Dual Tower Ignition Coil - BMW Airhead & Moto Guzzi; 3.0 Ohm; Primary Resistance / EnDuraLast
Part #: EDL-Coil3.0OHM
https://www.euromotoelectrics.com/product-p/edl-coil3.0ohm.htm
I can send a pic of how I mounted them if you wish.
Anthony Mrugacz
https://anthonymrugacz.net
View Past Stable of Ponies:
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
https://anthonymrugacz.net/
5Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 7:12 am
Bricklayer wrote:I used a set of these with great results:
How long have they been installed on your '85, and how miles have you put on them? Please post some photos and perhaps some description about your installation.
6Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 8:53 am
Chris Garrard
Chris Garrard
Post some photos please
7Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 10:22 am
Bricklayer
Bricklayer
Gheez, let me finish my Saturday morning coffeeeeeeee....
OK let's go!
A) Original cover used. Blue dots (rubber plugs) on right side something I had laying around.
BONUS: One can ream out the hole on a dual power accessory bracket for use with standard automotive plugs.
Ignition coils A-198510
B) Using a grinder I removed the rivets on the original coils to use the coil cover mounting brackets. This setup allows only the left side brackets to be used.
A homemade bracket from leftover parts after a bathroom sink repair cut and used to connect coils.
Ignition coils B-198510
C) Parts I cut and used to make bracket.
Ignition coils C-198510
D) Bottom View showing wires soldering inward.
Ignition coils D-198510
E) Rearview showing mounting setup.
Ignition coils E-198510
Installed last autumn before the winter snows and 200 miles ago, so far flawless performance. Great cold starts at freezing temperatures. While you are at it, now is a good time to remove the fuel tank and clean all the electrical connections.
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
8Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 10:28 am
Bricklayer
Bricklayer
I have also added high resolution pictures as a ZIP file for download from my non-commercial website.   Very Happy
1985 K100 Coil Mod
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
9Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 11:12 am
Can the administrators move posts 7 & 8 to the technical library?
10Back to top Go down   Ignition coils Empty Re: Ignition coils Sat Apr 29, 2023 11:18 am
Bricklayer
Bricklayer
Or maybe create a "HACK' category?
Necessity played drums for the Mothers of Invention.
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
