1 Need help K100 bike won't move when clutch is disengaged????? Sun Feb 10, 2013 11:36 am
billhutchsat
[img][/img]My K100 won't move when clutch is disengaged. I was on a ride going about 60mph when all the sudden I lost traction between the motor and rear wheel. Down shifed to a higher gear gave monentary traction to no traction. In first gear when the clutch is disengaged there is slight pull traction at the rear wheel but I have no problem holding the bike stationery with the clutch fulley disengaged and the engine running at any speed. I have done the following with no good indication as to what is causing my loss of traction:
Inspected final drive, driveshaft, transmission, clutch disk, clutch plate, pressure plate and all the splines, all appear not to be the cause for loss of traction. Prior to my loss of traction there was no clutch slippage, no transmission shifting problems, no irregular noise from either the transmission or the motor. The final drive and transmission moves smoothly as they should but I have not disassemble them for close inspection. The clutch plate seems to move properly but something is causing the loss of traction problem. Can I be loosing traction between the crankshaft and the outputshaft???? When I turn the attached clutch plate, I'm sure the crank and engine are also turning.
Any and all suggestion and comments are greatly appreciated and welcome.
Bill Hutchens
San Antonio, Texas
Bill Hutchens
San Antonio, Texas
