1Back to top Go down   [solved]powering accessories k100? Empty [solved]powering accessories k100? Sun Feb 10, 2013 1:08 am
TRIceberg
TRIceberg
85 K100RS. I don't have a powerlet plug on my bike. I have a "connection for special eqipment" and the "optional connection for anti-theft system." Can either of these be used to power accessories (GPS, Phone, etc)? If not, what is the best way to make this happen?
1985 K100rs
1972 R75
[solved]powering accessories k100? 8449926619_191bc78201_m
wherever you can find power hot from the battery attach a powerlet plug ( with fuse inline would be good) and from there you can run other power lines...so look in the vicinity of your left knee and there should be one there...if not here is a perfect place.
KKlompy [solved]powering accessories k100? 2854237993
[solved]powering accessories k100? Au-log10
TRIceberg wrote:I have a "connection for special eqipment" and the "optional connection for anti-theft system."
At both of these connectors you find a red/yellow wire which is unswitched and
protected by fuse # 5.
5Back to top Go down   [solved]powering accessories k100? Empty Re: [solved]powering accessories k100? Mon Feb 11, 2013 10:59 am
TRIceberg
TRIceberg
sidecar paul wrote:Have a look at this thread, TRIceberg:-
https://www.k100-forum.com/t5053-charging-socket?highlight=usb+socket
The one on Klompy's bike looks like it would work well for me, Thanks for the help everyone.
1985 K100rs
1972 R75
