1Back to top Go down   BMW K1100LT Fuses Empty BMW K1100LT Fuses Mon Feb 04, 2013 5:11 pm
Cafe-K
Cafe-K
Hey guys....tearing into a 1993 K1100LT strip down and rebuild. I can't
seem to find any info on the fuse ratings and locations. I looked
through my repair manual but all I could find was info on the relays.
This is what I'm staring at.
Christian
2Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:15 pm
Cafe-K
Cafe-K
Sorry having issues with the photo hope this works! So obviously this photo needs to be rotated 90* to the right to see what I'm seeing when I look at the bike Very Happy
BMW K1100LT Fuses Photo12
3Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:21 pm
BMW K1100LT Fuses Sikrin10
4Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:23 pm
gmcq
gmcq
Thanks Inge, all mine are 15amp, like that when i got her and was worried some had been over rated!
GMcQ
1996 K1100LTIC 0235790
5Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:28 pm
Edit: fuse #4, power socket only....headlight relays is non OEM.
6Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:42 pm
Cafe-K
Cafe-K
Thanks that's really helpful! And what I was afraid of too.....looks like the previous owner put fuses in there at higher than recommended ratings....
7Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 5:46 pm
English version,....after some search:
BMW K1100LT Fuses Sikrin11
8Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 6:27 pm
Cafe-K
Cafe-K
Thank you for the English version! I'm a German speaker and managed to translate the other, but this is very helpful! Thanks again Inge.
Christian
9Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 6:38 pm
Cafe-K wrote:I'm a German speaker and managed to translate the other,
The other is Norwegian.
10Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Mon Feb 04, 2013 7:26 pm
Might as well be hindi to a monoglot like me.
11Back to top Go down   BMW K1100LT Fuses Empty Re: BMW K1100LT Fuses Fri Feb 08, 2013 3:23 pm
Hi Christian,
Well worth replacing the fuses with the same pattern but using the fuses that include a little LED in them because if a fuse pops, when you have the ignition on you can see instantly which one is blown because the LED is lit up, also give them a squirt of DeoxIT too.
