1 does changing the rear drive change the odometer signal? Sun Aug 16, 2009 4:05 pm
roys
hi,
I recently replaced my 32:10 to a 32:11 rear drive. I have also replaced instrument cluster with one from a 1992 K75. So I now have a working odometer and can finaly calculate my fuel consumption. The calculated result seems too high I get slightly less then 13.6 KPL (34.3MPG) with mostly city driving 15.8 KPL (37.1 MPG) with fun driving outside of city (many twisting roads, speeds changing from 80-140KPH).
Do you agree that this is too high? so my 1st Q is if this is real or perhaps an artifact of "new" final drive?
If not an artifact then what can be done to improve this? - any adjustments I can play with?
I should add that that naked bike likely has more air drag and that I use the most common fuel available - the 95 octane kind.
perhaps others can comment on what they get per what kind of driving? If enough respond we can get some meaningful statistic.
Thank you,
Roy
Thank you,
Roy
