1Back to top Go down   Simple and inexpensive GPS bracket Empty Simple and inexpensive GPS bracket Fri Feb 01, 2013 11:17 am
puntolimitecero
puntolimitecero
I found a cheap Garmin Nuvi on a used articles trading page. The seller said that the cause of the low price has that had no sucker bracket.
Finally, I bought it, update maps and wors fine, mp3 player, phone handsfree, picture viewer, translator, units and currency converter,...
Simple and inexpensive GPS bracket 2B501AF321344FDBB32E3A4FDBAC74
Simple and inexpensive GPS bracket 22501AF1C2374FDBB1C0314FDBAB15
Simple and inexpensive GPS bracket 27501AF1E2414FDBB1EE364FDBAB35
This is one of the best utilities, because displays actual speed and serves as a travel computer.
Simple and inexpensive GPS bracket 25501AF1E03E4FDBB1EB344FDBAB33
It was time to build a bracket without cutting wires or plastics, completely reversible.
The GPS had a little back bracket with power input and headfhones.
Simple and inexpensive GPS bracket 23501AF1DE3B4FDBB1E8324FDBAB31
Simple and inexpensive GPS bracket 22501AF1DD394FDBB1E6314FDBAB30
I had to get a 17 mm diámeter stainless steel ball that fits in the housing and drill a hole to make an M6 thread, prepared two plates, get bolts and nuts...
Simple and inexpensive GPS bracket 21501AF1DC404FDBB1E4304FDBAB2F
Simple and inexpensive GPS bracket 1F501AF1DA3D4FDBB1E1374FDBAB2D
There are two possible mounting choices. This is the rudimentary one:
Simple and inexpensive GPS bracket 27501AF1D93B4FDBB1DF364FDBAB2C
Simple and inexpensive GPS bracket 24501AF1D6404FDBB1DB334FDBAB29
Simple and inexpensive GPS bracket 23501AF1D53E4FDBB1D9324FDBAB28
And this is the stylish one:
Simple and inexpensive GPS bracket 1E501AF1C73D4FDBB1C62D4FDBAB1A
Simple and inexpensive GPS bracket 24501AF1CD3C4FDBB1CE334FDBAB20
Simple and inexpensive GPS bracket 21501AF1CA384FDBB1CA304FDBAB1D
Simple and inexpensive GPS bracket 1E501AF1D0374FDBB1D2364FDBAB23
The second part is to provide electric power to the advice.
Simple and inexpensive GPS bracket 25501C28962F4FDCE8A4344FDCE1E9
Simple and inexpensive GPS bracket 22501C28A5334FDCE8BA314FDCE1F8
Simple and inexpensive GPS bracket 20501C28A3394FDCE8B72F4FDCE1F6
Once identified positive 12 volt power and ground paths, I soldered wires:
Simple and inexpensive GPS bracket 27501C28A1364FDCE8B4364FDCE1F4
Simple and inexpensive GPS bracket 25501C289F334FDCE8B1344FDCE1F2
Simple and inexpensive GPS bracket 23501C289D304FDCE8AE324FDCE1F0
Simple and inexpensive GPS bracket 22501C289C374FDCE8AC314FDCE1EF
Simple and inexpensive GPS bracket 1E501C2898324FDCE8A7364FDCE1EB
Female connector taking power from cigarette lighter plug under dashboard:
Simple and inexpensive GPS bracket 16501D0894314FDDC8AA2E4FDDC1E7
Simple and inexpensive GPS bracket 1C501D089A3A4FDDC8B32B4FDDC1ED
Simple and inexpensive GPS bracket 1A501D0898374FDDC8B0294FDDC1EB
Battery symbol on rigth upper part indicates that the GPS is receiving power from motorcycle:
Simple and inexpensive GPS bracket 19501D0897354FDDC8AE284FDDC1EA
Really, the matter was very very cheap.
Saludos
2Back to top Go down   Simple and inexpensive GPS bracket Empty Simple and inexpensive GPS bracket Fri Feb 01, 2013 4:44 pm
Excellent idea, you are pretty handy with the inventions.
Thanks for showing us
+1.......... Simple and inexpensive GPS bracket 112350
Very nice.....just how we like it innovative and inexpensive....perfect.
KKlompy Simple and inexpensive GPS bracket 2854237993
Simple and inexpensive GPS bracket Au-log10
I'm impressed!
Simple and inexpensive GPS bracket Ir-log1188....May contain nuts!Simple and inexpensive GPS bracket Ir-log11
K75RTP - 1994
AJ.Valente
AJ.Valente
I like this thread; Question: Does your GPS interfere at all with the ignition key?
Am planning on doing GPS on my bike as well. Considerin a model with bluetooth so it can communicate with bluetooth headsets.
Quick story; Last year was riding in upstate Vermont and got lost. So, pulled over and wipped out the iPhone with Google Maps. Unfortunately, no help as I was outside service area. Had to backtrack some 20mi. Crying or Very sad
puntolimitecero
puntolimitecero
There is no problem with ignition key:
Simple and inexpensive GPS bracket 2D50203A701E4FE0FA92184FE0F3C3
Besides, in case of interference, there wouldn't be problem neither, because is easy to remove GPS only by clicking and pulling:
Simple and inexpensive GPS bracket 2F50203A601E4FE0FA801A4FE0F3B3
Simple and inexpensive GPS bracket 3350203A761D4FE0FA9A1E4FE0F3C9
Saludos
puntolimitecero
puntolimitecero
It's easy to find cheap used Garmins on internet. Here you are a link to a spanish trading page:
http://www.milanuncios.com/anuncios/garmin-nuvi.htm?orden=baratos
Saludos
Ajays
Ajays
Not just one design but a choice.
Are you a toolmaker or design expert?
Very well done and put together with pictures. 10/10. I can see you will be an asset to Bert's forum
Ajays
Simple and inexpensive GPS bracket Th_Kengine_gif
AJAYS
10Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sat Feb 02, 2013 10:40 am
puntolimitecero
puntolimitecero
Is this Bert's forum?
Saludos
11Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sat Feb 02, 2013 10:46 am
Saludos
Well it wouldn't be a forum without ALL the people but the kudos for setting up this amazing site goes to Bert a.k.a Crazy Frog for setting up the forum from his own resto efforts. And yes puntolimitecero, you are definitely an asset!
K75RTP - 1994
12Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sat Feb 02, 2013 11:29 am
puntolimitecero
puntolimitecero
I understand, thanks.
Saludos
13Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sat Feb 02, 2013 2:16 pm
88KE wrote: Well it wouldn't be a forum without ALL the people
Simple and inexpensive GPS bracket 212902
I am currently busy with others projects and don't have too much time to dedicate to the forum. The forum is very active without my participation.
CF
Simple and inexpensive GPS bracket Frog15Simple and inexpensive GPS bracket Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
14Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sat Feb 02, 2013 5:21 pm
Bert Started this forum and because of the way he runs it and all of you who are really special people I believe it has become the premier K100/75/1100 forum on the world wide web. I joined pretty early on and am Bert's co ADMIN and I cover for him whilst he is away or tied up with work or projects. We have a brilliant team of Mods who do a great job and a reliable list server too.
Few people know just how much Bert does and the hours he puts in in-between a very demanding IT job, being a super home handyman/builder, a keen K rider and running this list. I think he has a special day just for him with 48 hours in it because if he only had 24 I don't think he could get it all done Smile
I would be astonished if there is another group of such knowledgeable people out there, I am pretty sure there is no K fact no matter how obscure that one of the team on this list doesn't know. As Bert AKA Crazy Frog has set this up we are a merry band of people who cooperate and help each other for no material gain, how good is that.
Good on you all!
15Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Sun Feb 03, 2013 5:29 am
jandalboy
jandalboy
Outstanding! Simple and inexpensive GPS bracket 112350
1990 k100rs low seat.
16Back to top Go down   Simple and inexpensive GPS bracket Empty Re: Simple and inexpensive GPS bracket Tue Feb 19, 2013 2:22 pm
dejavu
dejavu
useful information thanks Very Happy
BMW k1 - 1989
BMW R25/2 - 1953
Honda CB 450 Night hawk 1976
Mazda B 600 1975
Harley Davidson Sportster 1962
