1Back to top Go down   K1100rs rear wheel-fits k100+k75-UK Empty K1100rs rear wheel-fits k100+k75-UK Thu Sep 30, 2010 9:24 am
ssray
18x4.5j rear wheel, with well worn but not illegal Metzler z4(160/60/18). wheel has a few scrapes and paint chips, pics on request.
£20 collected or £30 by courier, Pm me or reply to post as emails did not get through last time.
Cheers Ray
green cat
green cat
Are you sure??? because before i put the k1 wheels on the k1100, i've tried it on the k100rs and the widtht of the wheel didnt allow me to install it...
[img]K1100rs rear wheel-fits k100+k75-UK 3cc2228804714fdc8e93fe1f84a93706[/img][img]K1100rs rear wheel-fits k100+k75-UK K1100l10
ssray
Remove the caliper and fit a k1100 stand.
Been on mine for 5mths just a bit of a squeeze getting it on and off.
Ray
beachcomber
beachcomber
Chat verte,
You can fit ANY wheel from the Kay range - just depends if you want to make any changes!
A guy on the K11OG site HAS fitted K1200 wheels to an otherwise stock K1100 - mine is obviously not stock ...............
I'm still working on the front conversion - taking time due to lack of facilities these days. However, looks fairly straightforward after I got a load of bum info. I'll use a spare set of K1100RS forks with a K1100 3 spoke wheel spindle - modified.
Here is the 5" 5 spoke fitted to my K100RS, and I have a 5.5" version fitted to my K1100 Race Rep project. I might just fit the 5.5" to the K100 Monolever as I now have the correct caliper / bracket combo.
K1100rs rear wheel-fits k100+k75-UK SONAVON065
Oldgoat
Oldgoat
Very slick Beachcomber! I've been looking into having Kosman widen my snowflakes so I can mount radials. Do you know what the max width is for front/back on the K100 before you have to start tweaking stuff?
Thanks!
J
beachcomber
beachcomber
Goat,
the 3 spoke K1100 wheel [ rear ] drops straight in - you might have to tweak the mainstand [ or ditch it ! ].
Rather than have your Snoflakes widened [ expensive?] why not go for the k1100 set up? Yes you will need K1100 forks, but I'm guessing cheaper / simpler than having the wheels widened - and of course there's the future replacement issue if you damage one !
3 Spoke wheels are pretty plentiful, although they seem to vary dramatically in price. Make sure you get RS wheels [ 4.5" rear ].
The K1200 5 spoke Wobbly wheels are the way to go for max width / tyre combo - but WILL mean some surgery to stand and no doubt a tweak of the exhaust - all NO probs for me of course !
Once I have the answer on the front 5 spoke - I'm hoping it will be a simple wheel spindle exchage / mod.
Oldgoat
Oldgoat
Thanks for the info Beach. :-) I'll have to start looking at used stuff and add up the costs for each alternative.
beachcomber
beachcomber
Here's the 3 spoke installed - still looks a LOT wider than the Snoflake !
K1100rs rear wheel-fits k100+k75-UK SONAVON034
beachcomber
beachcomber
Sorry don't know how to do multiple pix. Here's the Race Rep in mock up form - before I found out that the k1200 / r1150 5 spokes would fit.
K1100rs rear wheel-fits k100+k75-UK SONAVON164
Oldgoat
Oldgoat
Wow, like that Race rep! Shocked Thanks again Beach.
J
beachcomber
beachcomber
The next week we had the Yam R6 belly pan fitted - looked wrong, so now looking at the Profile K100 Belly pan moulded into the R6 top half. Does look good with the new upswept underseat exhaust system and those 5 spoke wheels.
Of course BMW fitted an R6 Fairing to the S1000RR when it was under development !!!!!!!!!!!!!!!!!!!!!!!!!
12Back to top Go down   K1100rs rear wheel-fits k100+k75-UK Empty Re: K1100rs rear wheel-fits k100+k75-UK Sun Oct 03, 2010 12:32 pm
ssray
You can fit a 17x3 from a K1100lt, without having to remove the caliper when you remove or refit the wheel and you can fit a 150/70/17 to that, the 18x4.5 will take a 160/60 but nothing bigger.
The thing I noticed with the 18 rear was it lowered the back end a bit and it lowered the gearing, not by much but noticeable.
The current wheel is a 17x3 and it feels quite a bit more flick-able and I prefer the gearing, the other thing i noticed was with the 160/60/18 I was getting to around 10mm from the edge of the tyre and on the 140/80/17 I`m hardly near the edge atall.
Ray
