1Back to top Go down   k100 motor Empty k100 motor Wed Aug 12, 2009 9:59 pm
yankeeone
Looking for 87 k100 motor with or with out acc. I live in mass USA hoping for lower miles good cond.
yankeeone_13@hotmail.com
2Back to top Go down   k100 motor Empty Re: k100 motor Thu Aug 13, 2009 6:20 am
Few are for sale on Ebay.
One with 72K is located in NC (Canton) and it could be a nice drive to go pick it up.
3Back to top Go down   k100 motor Empty Re: k100 motor Sat Aug 15, 2009 1:24 am
yankeeone
Hi, does any one know if an 85 motor will fit, in 87 k100 and would it be a better motor?
4Back to top Go down   k100 motor Empty Re: k100 motor Sat Aug 15, 2009 6:03 am
The engines are almost the same.
The 2 engines have the same physical size.
I believe the major differences on the 1987 are:
- Oil/water pump with a newer design for the water turbine and seals.
- Output shaft has 12 rivets in stead of 6 on the 1985.
- different design of the pistons and rings (newer models don't smoke after being parked on the side stand).
- The vacuum switch was also discarded by late 1985 (Many people had removed this switch on 1985 models).
A swap between a 1985 and 1987 would not require any modification on the bike.
Bert
5Back to top Go down   k100 motor Empty Re: k100 motor Wed Aug 19, 2009 8:48 pm
yankeeone
Bert, I am waiting for a 85 motor, trans, and rear drive from Fla. When I switch them , can I switch the harness and use the ecu that is on my bike, I hope .
Thanks for your help
Brian
6Back to top Go down   k100 motor Empty Re: k100 motor Wed Aug 19, 2009 9:39 pm
yankeeone wrote:Bert, I am waiting for a 85 motor, trans, and rear drive from Fla. When I switch them , can I switch the harness and use the ecu that is on my bike, I hope .
Brian
It should not be any problems at all.
Good luck and let us know about your progress.
Bert
