1Back to top Go down   Fork damper component help Empty Fork damper component help Mon Jan 06, 2020 5:04 pm
Steve2
Steve2
BMW K1100 1996 UK
Hi I need a bit of help here. Ive stripped down my forks ie off the bike, removed the stanchions from the sliders but not the stanchion internals ie spring etc. What I have found sitting underneath the top of the stanchion nuts/ top caps (?)  are two washers with four holes in. These are approx 3.7mm thick and appear to seat on the internal shoulder of the top caps. However the washers one in each stanchion are identical one seats perfectly and the other wont quite seat as there is a slight lip on one of the top caps. This lip doesnt look like any kind of wear groove as they're anodised and that looks to be fine. The result is the washer sits up off the main shoulder by about 4mm.
So my question is what are these parts as they are not shown on my exploded fork diagram and secondly assuming they are supposed to be there should they seat right down on the shoulder in both top caps. I remember one being hard to get out and had to be tapped out.
Any help much appreciated.
Steve
K1100 LT 1996 VIN 0183069
2Back to top Go down   Fork damper component help Empty Re: Fork damper component help Mon Jan 06, 2020 10:35 pm
To get a better understanding, pictures would help.
3Back to top Go down   Fork damper component help Empty Re: Fork damper component help Tue Jan 07, 2020 12:25 am
Photos are needed, as Martin indicated. Do they look like these?
Fork damper component help Screen94
You'll also find them in drawings here, under 31–Front Suspension
4Back to top Go down   Fork damper component help Empty Re: Fork damper component help Tue Jan 07, 2020 4:49 pm
Steve2
Steve2
The diagram seems to be the forks Im working on.
The photos shown in the link show the slight lip in one of the caps .09mm which stops the shim sitting on the shoulder. Any ideas of how I should resolve this. the shim sides dont look to be exactly precision made so maybe dress them up ? ( Neither of the shims sit correctly in the cup with a lip.
http://forum.kforum-tech.com/members-upload/uploads/BMW_Fork_Caps.docx
Thanks for the help so far and any future tips. I couldn't figure out how to add images directly into this post sorry !
cheers Steve
5Back to top Go down   Fork damper component help Empty Re: Fork damper component help Tue Jan 07, 2020 5:33 pm
Steve2 wrote:. . . so maybe dress them up ? ( Neither of the shims sit correctly in the cup with a lip.
I wouldn't be dressing the shims until you have complete understanding of their fitment. Be patient. Somebody with relevant experience will chime in.
Your docx link doesn't work for me; pictures must be posted using forum software or links from a photo hosting site like imgur. Try using the photo posting instructions in the Forum Functionality section of the site. Of the forums I use, this site's system is the easiest for posting photos from a computer.
6Back to top Go down   Fork damper component help Empty Re: Fork damper component help Tue Jan 07, 2020 6:39 pm
Fork damper component help Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
