1Back to top Go down   Side stand Empty Side stand Mon Dec 24, 2012 8:30 pm
Should my side stand be straight? The PO has put a block on the bottom of it and I removed it to see why. It seems to have a slight bend in it, is that normal?
2Back to top Go down   Side stand Empty Re: Side stand Mon Dec 24, 2012 10:30 pm
Have a look at this this thread on the subject of side stand blocks - or "pucks" as some call them. Mine was very bad but before attaching the block I replaced the bush and bolt on the side stand mount. In the end I never needed the block.
88KE
Side stand Ir-log1188....May contain nuts!Side stand Ir-log11
K75RTP - 1994
3Back to top Go down   Side stand Empty Re: Side stand Tue Dec 25, 2012 12:30 am
some great options provided by all.You should be able to select from at least one of those.
My centrestand has broken and the sidestand as far as I know was bent on delivery when purchased a few years back.
So I have persevered in the meantime.
Constructed from steel C section with a rubber block inserted from below. It at least provides for a more upright position, and when pulling up in the entrance of my driveway it grips on the slope. I do however encounter less clearance on servo driveways and speed humps..
hopefully you don't resort to my crude attempt. It has been in place for a while, simple , but it works,
I much prefer the cheeseboard option.Looks a bit more professional.
Side stand 152514
cheers Ed.
This block puts the bike at about 70-75 degrees.
Side stand 10_x_110
4Back to top Go down   Side stand Empty Re: Side stand Tue Dec 25, 2012 2:10 am
bikerboy wrote:Should my side stand be straight?
No, all sidestands have a slight bend.
5Back to top Go down   Side stand Empty Re: Side stand Tue Dec 25, 2012 2:36 am
aye ...indeed +1
6Back to top Go down   Side stand Empty Re: Side stand Tue Dec 25, 2012 11:36 am
Thanks guys, that will save me putting it in the vice and getting the blow torch out to remove the bend.
7Back to top Go down   Side stand Empty Re: Side stand Tue Dec 25, 2012 8:01 pm
I bought a cheap plastic puck which fits on the sidestand and has a magnet in so that it sticks to the sidestand which I use when parking on grass which is a bit soft or where the sidestand is prone to burying itself and allowing a tip over. I have a string on mine which I tie to the handlebar and when I retract the sidestand with my heel I can haul in the puck and pop it into a plastic bag and pocket it before riding off (the magnet will not hold the puck on when the bike hits a bump I found). Downside is if you use a compass don't use it near the pocket with the magnetic puck in Smile
K-BIKE.
8Back to top Go down   Side stand Empty Re: Side stand Sun Jan 13, 2013 1:13 pm
Side stand is now as straight as an arrow. Took it off to fit a new bush which did not seem worn, put it in the vice, used a blowtorch and bent it straight. Now painted and fitted.
9Back to top Go down   Side stand Empty Re: Side stand Sun Jan 13, 2013 2:04 pm
ReneZ
ReneZ
BTDT.... I ended up buying a new side stand only to find out there's a knick in a new one as well ;-)...
Rene
BMW K100 - 1985 (0030029) Scotland Side stand Rain
10Back to top Go down   Side stand Empty Re: Side stand Sun Jan 13, 2013 3:00 pm
Ajays
Ajays
I recently posted that I had just rebushed and straightened after heating my side stand. It sits about right now but if you lower the adjustment on the rear tensioner to the soft position it does effect the lean. So before adding a block I suggest you put it to soft first.
Side stand Th_Kengine_gif
AJAYS
11Back to top Go down   Side stand Empty Re: Side stand Sun Jan 13, 2013 8:19 pm
Thanks Ajays,
great thing about this forum is you learn something new every day.
Side stand 10_x_110
