1Back to top Go down   Help! Problem refitting injectors Empty Help! Problem refitting injectors Thu Jan 10, 2013 12:30 pm
MartDude
MartDude
Hi, I could do with some advice, please (and yes, I have searched on here, but haven't found quite the info I need)
I'm replacing - or trying to replace - the injector o-rings on my '89 K100RT. And I'm having trouble in getting the injectors back in to their housings on the fuel rail - it takes an unexpected level of force to get them in, and I'm finding it difficult to get them in straight; I've already damaged 2 o-rings. Is there a special technique for this operation? I'd lubricated the rings with fresh engine oil.
If it's this hard on the bench, how will I get the injectors properly seated in their housings in the head?
The new o-rings came from a reputable supplier - MotoBins - so I'm sure they're the correct item.
When I removed the injectors, instead of the injectors & fuel rail coming off together, the fuel rail pulled off, leaving the injectors behind. The injectors themselves where a real pig to get out - required a lot more force than I expected - resorted to levering them out with a pair of cranked long-reach pliers.
Thanks in advance.
mart
yes i imagine they would be hard to pull out ....rubber sets quite nicely after many years of being in the same place
the fuel rail rubbers should be tightish also .....perhaps you might clean up the injector to head interface with maybe a rag and some degreaser , making sure that there are no rubber fragments left from the remooval phase and that the bores that you will be pressing into are well lubricated ...perhaps you could use vaselene sparingly for that ?
when i did my injector clean up ...i was surprised also at the force required ...but im assured by many that this is correct .
good luck !
yankeeone
wipe some assembly lube on them, pop right in.
Brian
That is one of the very few places where silicone grease or so called di-electric grease should be allowed to contact the K the other one being the spark plug caps to stop the rubber bonding to the ceramic of the spark-plug.
charlie99 wrote:..perhaps you could use vaselene sparingly for that ?
I may be wrong but I was under the impression that Vaseline was destructive to rubber. I know the O-rings are Vitron, even still...
6Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Thu Jan 10, 2013 10:05 pm
had the same thought rob ...then cleared the head with what was i thinkiing ...theres petrol in there just about all the time a little vassolene isnt going to hurt at all .
ReneZ
ReneZ
Vaseline = petroleum jelly???? !
Rene
BMW K100 - 1985 (0030029) Scotland Help! Problem refitting injectors Rain
same thing rene
but for all other rubbery stuff i use this ...makes fitting the tank into those rubbers a breeze
good for - 45 d f to +450 d f
Help! Problem refitting injectors 2013-010
Silicone from a aerosol can functions good for this use.
10Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Fri Jan 11, 2013 6:48 pm
Themason
Themason
I lick the o-rings to lube them for insertion. Saliva won't rot the o-rings.
1986 R-80G/S w/1000 cc engine
11Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Fri Jan 11, 2013 7:23 pm
twincarb
twincarb
Themason wrote:I lick the o-rings to lube them for insertion. Saliva won't rot the o-rings.
Can you imagine how many germs you are potentially giving your K??? If you had a cold it could transfer and you would be left with a bike that coughs and splutters! Wink
Yamaha Thundercat
Help! Problem refitting injectors 169042Help! Problem refitting injectors 169034
12Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Fri Jan 11, 2013 7:58 pm
Help! Problem refitting injectors 44271 Help! Problem refitting injectors 44271
13Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Sat Jan 12, 2013 10:53 am
ReneZ
ReneZ
Going back to the O-rings, there's a very tight fit in the fuel rail (as it should be able to take the full pump pressure without leaking), but normally warming them up will help (short while in boiling water??) to make them more pliable.
Rene
14Back to top Go down   Help! Problem refitting injectors Empty Re: Help! Problem refitting injectors Fri Jan 18, 2013 12:48 am
Themason
Themason
[quote="twincarb"][quote="Themason"]I lick the o-rings to lube them for insertion. Saliva won't rot the o-rings.[/quote]
Can you imagine how many germs you are potentially giving your K??? If you had a cold it could transfer and you would be left with a bike that coughs and splutters! Wink [/quote]
Keeping a dog as a pet you learn not to be too fussy about these things. Hair and slobber are all good.
