1 !988 K75S headlight switch dismantled picture. Thu Jan 03, 2013 7:39 am
BooG
Nice clean switch, but still no main beam! Again, I have the hi beam and sidelight, but no main beam. I guess its time to dig out the multimeter and stab some contacts!
Here is a picture of the parts making up a Headlight/Emergency Stop/signal/cancel signal switch for an 88 K75S. There are cheeky springs at the rear of the kill switch that can fly. Also, the headlight switch itself with that tiny ball bearing. The signal cancel has a spring and that brass piston. I did the bag trick and nothing escaped, and checked all continuity during re-assembly. Its a bit dim, but you can make everything out.
How do I get the pic up?
