1 K100RS 16 Valve breather tube Fri Jan 04, 2013 12:52 pm
MT350Explorer
Hi Guys,
Bit of time off over the New Year and a list of things to do including, fitting new pads up front (anyone with Brembo's know a technique to do this? - the calliper fit is crazilly tight against the rim making it a battle to get them on and off) and change the crankcase breather tube.
The breather tube I knew was split after I worked on the TB's but I taped it up and the bike ran OK. To be honest I've had the new part for ages but put off fitting it as the whole airbox/TB area IMHO is a complete git to work on unless you're some sort of masochist (like Rene, apparently he likes it 'in there' )!
Anyhow, I really just posted up the pic to show the inside of the 16 valve box and the tube for info. The tube split just outside the airbox - you can see the tape.
Jobs done I went for a ride - an unexpected dry and mild spell - bike running beautifully!
Dave
Dave
1991 K100 RS 16 valve
