1Back to top Go down   crankcase breather tube Empty crankcase breather tube Tue Jul 10, 2012 1:45 am
marten
I'm about to reassemble my 86 K100RS and want to order the last missing parts.
I could not find the crankcase breather rubber hose in the parts fiche.
can someone direct me to it or has the parts number?
Thank you
Marten
2Back to top Go down   crankcase breather tube Empty Re: crankcase breather tube Tue Jul 10, 2012 1:48 am
11 15 1 460 480 ?
Real OEM
3Back to top Go down   crankcase breather tube Empty Re: crankcase breather tube Tue Jul 10, 2012 1:49 am
It's shown with the engine block in one of the first images in section 11 of ETK.
Part number 11 15 1 460 480.
4Back to top Go down   crankcase breather tube Empty crankcase breather tube Tue Jul 10, 2012 2:04 am
marten
Thank you for the quick response!!!
so there is the little bugger and wants $ 16!!
Thanks again
Marten
5Back to top Go down   crankcase breather tube Empty Re: crankcase breather tube Tue Jul 10, 2012 2:06 am
6Back to top Go down   crankcase breather tube Empty Re: crankcase breather tube Tue Oct 30, 2012 11:24 pm
wngnutmv
wngnutmv
Humor me here, please. Could you cut the hose and put a breather filter on the end of the hose coming out of the crankcase and plug the air box fitting? Is there a vacuum issue or is this simply a crankcase vent? Just brainstorming.
crankcase breather tube CrankcaseBreather_00
Mike
"Wingnut"
85 K100RT (VIN 0D50672) 70,000+miles
"Gretchen II" (Gretchen von Gearshiften)
7Back to top Go down   crankcase breather tube Empty Re: crankcase breather tube Wed Oct 31, 2012 1:23 am
Its meant to do the same job as a PCV valve. with your idea you will find the engine would run OK but the small filter would get oil soaked very quickly. Personally I would not do it.
You can get the hoses go to http://www.motobins.co.uk/bmw-parts.php?model=K%20Series and search for engine breather hose
And you have it for about $16-$17.
