1 K100/1100/1200 Frankenbike monster Sun Dec 23, 2012 3:03 pm
Themason
My BMW tech friend, the guy who worked in Research prototyping the original K100 and K75 has a fertile mind. Some years ago he did some hard thinking on the limits of the K1100 and decided to try placing a two valve K100 head with 284 degree cams and Bosch L Jetronic on a K1100 block. This is not a simple or straightforward swap, so don't try this at home kids. The result was about a 15 horse [i]increase[/i] in power, a great reduction in heat and the elimination of some heat related Nikasil failures near the top of the bore on the exhaust valve side that are more common to K1100s than most owners of them realize. I just threw away a low mile K1100 engine I was intending to use in my own Frankenbike project for this exact reason (I have one more used K1100 engine left). Those engines run far too hot. Replacing the stock head with an old K100 two valve head with all that extra coolant, and replacing the stock 2 row radiator with a 3 row radiator from an eary K100 yields a very long lived motor, and a nice increase in output.
He had always wanted to see how a K1200 engine responded to L Jet but there isn't enough room to stack up the L-Jet plenum on the K12 throttle bodies in K100 frame. L Jet doesn't work at all on the stock K1200 chassis. Well, he found a way (yes, my lips are sealed) and the result is epic. This engine is mounted in a K100 frame with a K1100LT driveline and Paralever. It also uses a very early conventional GSX/R 1000 fork, triple clamps, front wheel and brakes.
If anyone ever says BMW K bikes are slow and boring, they need to ride this bike. Acceleration is explosive, as in Holy Sh1t! explosive, especially since this thing is a naked roadster and is a good 45 kg lighter than a K1200RS. The only criticism I have is it will buzz your fingernails off. There is a reason BMW put the 1200 cc iteration of the Flying Brick in a rubber mounted frame. Short conrods with a long stroke make for a buzzy powerplant. I wouldn't put it in a touring bike, it's too crude, but for a Sunday canyon scratcher, this thing with his chassis set up and the right set of new tires would humiliate a lot of supposedly superior sport bikes. My friend knows how to tune L-Jet to give a result superior to Motronic and this thing is an effin howler! And it looks so boring and innocent, heh, heh, heh.
1986 R-80G/S w/1000 cc engine
