1Back to top Go down   Water in Final drive casing Empty Water in Final drive casing Sun Nov 25, 2012 6:08 am
coopz
coopz
When changing oil in final drive I noticed a white colour oil indicating water presence. I changed oil regardless after cleaning out inner casing. Theres is a small weep from casing near upper part of casing.next to disc rotor. Should I replace outer oil seal and large O ring many thanks in advance Coopz
1985 K100 RS
2Back to top Go down   Water in Final drive casing Empty Re: Water in Final drive casing Sun Nov 25, 2012 6:16 am
Halo
Halo
Yes the orings compress with time and need replacing very cheap even from your local BMW shop
Halo
84 K100RS 0014803
93 FZR1000 EXUP
3Back to top Go down   Water in Final drive casing Empty Re: Water in Final drive casing Sun Nov 25, 2012 7:40 am
Also check that the O-ring at bottom of the breather is undamaged, and the small hole in the breather is facing rearwards.
Early models didn`t have this O-ring (and small hole), and it was a problem with water entering the FD via the breather.
This mod was done somewhere late -84.
Water in Final drive casing Lufteh10
4Back to top Go down   Water in Final drive casing Empty Final Drive problem Mon Nov 26, 2012 12:32 am
coopz
coopz
Many thanks guys for replies I'll check that out Coopz
1985 K100 RS
