1Back to top Go down   1988 / 1990 K100LT compatability Empty 1988 / 1990 K100LT compatability Sun 11 Nov 2012, 22:38
Rickmeister
Rickmeister
I am considering making an offer on a 1988 model K100LT, with supposedly only 15 000 Kms on the clock. Mine is a 1990 LT, and was wondering if most of the bits were compatible.eg, final drive, drive shaft, clutch, gearbox , disc rotors etc etc.
Thanx, Rickmeister.
The only thing you would find that is any real difference is that the secondary shaft will be a 6 rivit in the 88 and in the 90 it may or may not be a 12 rivit.
Rick, may I suggest you check out the stud holding the rear suspension before you buy it. And of course you must get another yellow bike.
1988 / 1990 K100LT compatability 44271
blast checking the stud stan ....change it anyhow before it breaks
hmm... seems a thought ulrick ...or are you just peeved off with the breakage ?
the northern mob is always looking for contributions to science and buggering about,.if your feeling generous ...grin
good luck with it, whatever you decide. but your "yellow peril" has been a strong hack ol mate.
